clutch help for a 2.2
I have a 2005 cobalt with a 2.2. I am in the process of a zzp stage 3 turbo biuld and i need a new clutch. Should i buy a flywheel and if so what kind? and what clutch do you recommend? i want to spend as little as possible but still have good components
if your going to get a clutch, you really should probably get an upgraded flywheel as well since you will already have it all out.
I would recommend the spec clutch probably the stage 3 or 3+
The fidanza flywheel would save you a few bucks vs the spec flywheel. Actually about 150 or so.
Whenever your ready let us know and we will take care of you!
I had a light flywheel in my cobalt s/c and hated it. I would just keep the stock flywheel. From a roll the car was great, but launching the car was tricky it would just spin alot of the time since the rpms went up so quickly.
