clutch messes up
Old Mar 31, 2010 | 10:19 AM
blackedout06's Avatar
clutch messes up
sometimes if i stomp on it in 1st gear and power shift to 2nd the clutch wont grab at all. it doesnt slip any other time n it doesnt do it all the time when i powershift either, just every now-n-then. almost like the pressure plate isnt doing its job sometimes idk. anyone else have this problem? i might end up buying n aftermarket clutch sometime this year just to get rid of the problem all together. anyone have any ideas?
Old Mar 31, 2010 | 10:26 AM
BLAZIN07SS's Avatar
I'm too JDM for you
if you dont have traction at the top of first gear and slam 2nd, the clutch will slip. the pressure plate cant hold up to that. try catching complete traction before hitting second gear. this may require you to feather the throttle a little
Old Mar 31, 2010 | 10:38 AM
08SSTCRD's Avatar
I've heard the LSJ clutches are notorious for this.
The 1st to 2nd ratio gap is quite large, so often the clutch will slip because it can't grab due to the difference in RPM on a hard 1-2 shift or 1-2 powershift.
Old Mar 31, 2010 | 11:31 AM
so getting a new clutch will stop this from happening correct? my dad drove it the other day n it did it to him n he thought he broke it n told me i need a new clutch. it has done it to me a couple times before and a friend of mine has had his do it for the past year n his clutch is still holdin up just fine other then doin this. so i figure get a new clutch by the end of this year and just solve the problem.
Old Mar 31, 2010 | 05:52 PM
08SSTCRD's Avatar
A high performance clutch with higher torque holding capacity should definitely solve the issue.
Old Apr 1, 2010 | 08:24 AM
yeah im thinking of going with the ACT organic clutch for like $280 or something like that. says it holds more torque and is good for street cars
Old Apr 1, 2010 | 08:28 AM
twzted's Avatar
Just get the GMP clutch, its cheaper.
Also, the clutch could be shot...or just glazed...drive it around for a couple hundred miles normally, just calm daily driven, no WOT shifting or anything and it should bring it back if it is just glazed.
Old Apr 1, 2010 | 10:08 AM
Iam Broke's Avatar
Isn't the GMP LSJ clutch just the LNF clutch I have for sale?
Zharrington_2010LNF
Feb 8, 2016 01:43 PM
RaginChopsuey
Oct 27, 2015 01:27 PM
no_ss
Oct 18, 2015 11:58 PM
SSLOW06
Oct 1, 2015 07:21 PM
jmelton327
Sep 26, 2015 10:04 PM
