Clutch position sensor help
Ok guys, Im having issues with my clutch position sensor/switch whatever, pretty sure its at the end of its life. I have no issues with cruise control, so im pretty sure its not the top sensor. Throwing code P0808 I cant seem to find the switch on the pedal assembly. Anybody got any info on location of it, and I cant seem to find a part number to get a replacement, I say clutch position sensor or switch at my local auto parts store and they have no idea what im talking about. This is getting annoying, When the car does start its fine no hesitation at all runs great. When it dont, radio comes on, everything electronic, even hear the fuel pump kick on but you turn the key and nothing. any info and help would be greatly appreciated. And yes ive used the search feature and havent been able to find the exact info I need.
Are the clutch position sensor and the starter saftey switch 2 different parts or both in 1? I have a code reading for clutch position sensor and when i look it up on rockauto its labeled clutch position sensor/starter saftey switch. Also i have no problems with the car starting with clutch engaged/not starting when not engaged but cruise control no longer works since code came on. Alldata shows them as 2 different parts right next to each other(up top against firewall behind steering column) but my car has one up top and one down towards bottom of pedal thats easily accessible like tje picture gelladuga69 posted. Someone help please!!!
The GM part number for the switch is 22734989.
Sl0wbaltSS
Nov 21, 2018 11:11 PM
