Clutch question
Old Mar 27, 2009 | 05:12 PM
prvdoughnut's Avatar
Clutch question
Ok i am planning on getting a new clutch when mine ***** the bed. Ill assume this will be sooner then later considering i learned on teh clutch. i never burnt it or anything but i got **** luck. anyways this is my daily driver and i want to keep it for a long time. but i do want to throw a turbo on it for some extra power. i dont plan on doing anything huge. maybe going to 200-225 hp so i dont think i need to build the engine up or anything but when i do replace my clutch what should i be looking into and how long would that clutch last under normal conditions.
i dont wanna break the bank with this either. and im looking at the zzp turbo kit for 2k
Old Mar 29, 2009 | 12:47 AM
anyone help?
Old Mar 29, 2009 | 07:16 PM
nothing
Old Mar 29, 2009 | 07:21 PM
TurboTechRacing's Avatar
For turbo applications I would suggest looking at the SPEC Stage 2+. It should last (if you drive well) a long time (50-100K miles) If you beat on it, it will not last as long... The stage 2+ will hold the power you put at it.
You dont want to go with a cheap clutch, as the price of the clutch is only half the cost... The other half is the install/labor to put it in... So do it once and do it right and save in the end...
Old Mar 29, 2009 | 09:52 PM
i know i was considering doing it myself and i was looking at the spec stage 2+ clutch but like is it good for driving around town? is it extremely different from stock clutch and will i need a new flywheel?
Old Mar 29, 2009 | 10:04 PM
Stage 2+ is very streetable...
You will either need to have your stock flywheel re surfaced or get a aluminum flywheel (spec to keep the same brands together)
Most just get the aluminum flywheel so they dont have to worry about trying to find a place to re surface and do it right...
Old Mar 29, 2009 | 10:18 PM
so this new clutch is good on the street and able to handle the turbo kit? so its the one im lookin for basically?
Old Mar 29, 2009 | 10:33 PM
AzulitoAlero's Avatar
I dunno you may want to look into the clutchmasters stg 3. After extensive research I decided on that clutch, and i picked up a Fidanza aluminum flywheel for a good price.
I am not going to put down huge hp #'s, but I just wanted a really long lasting, semi-aggressive clutch. the stg 3 is for cars up to 300 or so hp.
my second choice would have been an Exedy.. tried and true!
However, any way you decide to go, I would def recommend a new flywheel! They can be surfaced, but who trusts someone to do it perfectly?
Old Mar 29, 2009 | 10:41 PM
i dont need the 500$ spec flywheel? the fidanza one for 300 will be fine?
Old Apr 2, 2009 | 02:57 AM
mattcossel29's Avatar
yes.. yes you did... lol
Zharrington_2010LNF
Feb 8, 2016 01:43 PM
RaginChopsuey
Oct 27, 2015 01:27 PM
brandon04
Oct 21, 2015 07:04 AM
SSLOW06
Oct 1, 2015 07:21 PM
