Clutch Replacement
Old Aug 20, 2017 | 02:36 AM
Raptorunbound's Avatar
Clutch Replacement
Hey guys
just had a couple questions about replacing the clutch on an 07 LSJ.
I'm trying to figure out how exactly the tranny is supposed to detach from the engine. I have disconnected all of the bolts that hold it as far as I know and I also am having some difficulty getting the sub frame out. Is there some hidden bolt on the tranny and/or subframe that holds them in? Hoping to get some advice.
I've done a ton of research on here and followed everything as far as I know. Only thing I couldn't find that would be extremely helpful is pictures with one of the guides.
Old Aug 20, 2017 | 04:56 PM
exninja's Avatar
Did you unhook the two lower mounts? Steering rack? Roll bar?
Old Aug 21, 2017 | 09:19 AM
jdbaugh1's Avatar
Are you following a procedure or just giving it a go? I've personally not removed JUST the transmission but I do know there are very detailed instructions in the LSJ build book that might help you find something that got overlooked. https://onedrive.live.com/?cid=7F254...212944&o=OneUp
Old Aug 21, 2017 | 03:50 PM
The steering rack was the issue on the sub frame. As far as the tranny itself, apparently there was a hidden bolt we couldn't find. We got it though! Thanks
Old Aug 21, 2017 | 03:54 PM
Also, that book would have helped out a ton. We tried using the haynes manual and it wasn't nearly as in depth as that one.
Old Aug 27, 2017 | 10:21 AM
Ok so I've been driving it around after the new clutch installed and noticed the rpms don't lower at all when I press the clutch in or put it into neutral. Cruise controll still works and it didn't get the P0833 code. Any ideas what else may cause that?
it's a gmpp clutch and a new flywheel if that makes any difference.
thanks!
Old Aug 27, 2017 | 03:40 PM
Sharkey's Avatar
what does it idle at? did you have the throttle body or blower off for any reason? are your vacuum lines all ok?
Old Aug 27, 2017 | 03:57 PM
63 Nova SS's Avatar
This^ does it shift fine? What kind of rpm are you seeing when you push the clutch In and hold it?
Old Aug 27, 2017 | 05:07 PM
It tends to hover around the rpms it was at when I put it into neutral not really a specific area. It will go down almost instantly when I come to a stop though. I did take the supercharger off just to get a little more room when working from the top. As for the lines, they all looked good when we were putting everything back in.
Old Aug 27, 2017 | 05:08 PM
it does the same thing if I set it into neutral or hold the clutch in. Just hovers around the rpm it was at when I started. It shifts like it should. Sometimes a little stiff but nothing it never did before.
Old Aug 27, 2017 | 05:32 PM
Sharkey's Avatar
if the rpm is only staying up while your coasting with the clutch in or in neutral thats 100% normal. the ecm if programmed to do that as it helps smooth the shifts out as it reduces drivetrain shock.
Old Aug 27, 2017 | 07:41 PM
Hmm. It's only started doing it after the new clutch though. I wouldn't think it would change that.
Old Aug 29, 2017 | 08:45 PM
Just got an engine light today. Could one or all of these be the cause for that?
P2229
P1182
P2261
Old Mar 31, 2018 | 01:36 PM
MG-Maxx's Avatar
Raptor,
Doing the same job and having the same issue with finding a good write up with pics.
I am not able to find the bolts on top of trans. Where was that bolt you had difficultly finding?
Old Apr 1, 2018 | 12:11 PM
63 Nova SS's Avatar
There is one around the starter that's nots easy to find.
