clutch rod?
Old Mar 13, 2014 | 08:34 PM
crasycowi's Avatar
clutch rod?
Any one needing to use these after they install a new/upgrade pressure plate. im having issues when shifting at high rpm and going into reverse.
ZZPerformance - Adjustable Clutch Rod for Cobalt #
Old Mar 13, 2014 | 08:43 PM
Gelladuga69's Avatar
Which plate/kit did you go with? My car has been through two new kits of the ACT kit with their PP and have not replaced the clutch rod.
Old Mar 15, 2014 | 09:49 AM
crasycowi's Avatar
I now have a spec 2+ installed. I had the act with no problems but it wasn't strong enough so I had to bigger and when I did I started to have the problem
Old Mar 15, 2014 | 10:17 AM
Erik's Avatar
I experienced the same after installing a stage 2 Southbend clutch and Fidanza flywheel. A bit more notchiness. I also bought the clutch rod but felt no need for if 'til now that swapped my shifter bracket. Don't know why but my 2nd gear hasn't been the same since.
Zharrington_2010LNF
Feb 8, 2016 01:43 PM
ineedacobaltss
Nov 7, 2015 02:25 PM
SSLOW06
Oct 1, 2015 07:21 PM
Stuff
Oct 1, 2015 05:47 PM
