clutch, slave, master cylinder, or shift cable?
My car has been in the shop over 2 weeks now. New exedy clutch kit and master cylinder. Master cylinder replaced twice trying figure out the problem. Car will not shift gears while running. But you can start the car in gear. What could be the problem? thanks for any help. oh did i mention the shop wants to take it apart and try replacing clutch kit again but charge a 2nd time for labor.
When you say it won't shift when running, do you mean the shifter won't move or nothing happens when you move the shifter around? And what does it do when the car is not running and you try to shift?
the shop told me that it won't shift gears when running. that if you bearly let off the clutch it takes off if you start it in gear. i'm not sure what he means by that. i think he means it won't move when running. when not running it shifts fine.
What clutch and flywheel did you get? Did you replace throw out bearing? It almost sounds like the pedal is adjusted too low. Did you get one of those clutch rods?
Have asked Chevycobaltss3? He's in KY, maybe you're close enough to him that he can help.
i didn't replace the flywheel shop said it looked ok. clutch rods??? what is that? i'm not doing the work myself it is in the shop still. no i haven't asked Chevycobaltss3. but i'll look him up and ask him thanks
Almost sounds like it just needs bled out. Could just be air in the lines. Because if the clutch is grabbing that low on the pedal it sounds like the throw out bearing is not extending out far enough and therefore not getting the pressure plate off the clutch. That would explain why it starts to move after barely letting off the pedal and why it won't shift. It's like if you tried to shift when pushing the clutch in just a little bit, it won't let you because the clutch isn't disengaged enough
i replaced Pressure plate, Disc, Slave cylinder & Throw-out bearing Assembly with exedy clutch kit *GMK1010EXEDY*
This would be a lot easier if you had some video footage or if you were doing the work yourself. Relaying messages makes it hard sometimes.
Is it possible he put the cables on wrong? Does the clutch pedal have a normal feel to it? Like, does it move freely and completely in its travel?
As far as the shop charging you labor again... If its not their fault the problem exists and it is b/c of a faulty part then yes, I would say its fair that they charge you but if its their fault b/c of incorrect installation or other shop error then no. Problem is, you're not ever gonna know b/c they sure as hell will just say its a bad part whether or not it really is.
Good luck. Please keep posting details. Maybe you could go and take some video footage?
how would i know if the parts are bad or not?
I was having a similiar problem. now the only time i can put it in gear is with the car off. The clutch never fully disengages. I don't know what the issue is with mine. I just ordered all new parts and hope to have James help me throw them in.
just ordered exedy gmk1010 clutch set again. going to let him taking it apart again and replace parts. so now i'm look at 730 labor (first time was 450 clutch + 30 master cylinder now + 250 clutch again) + 255 clutch set + 100 master cylinder + 20 fluid + 150 flywheel + 50 tow fee so about 1,305. hopefully this fixes it this time.
it may be the pressure plate i had similar issues when a spring fell out of my plate and disc i had to start the car in gear and it would barely shift
now i recently had my throw out fail and i could still drive my car and get it to switch gears on or off it would just engage at the bottom and leak fluid
