clutch slipping and lsd question
Old May 1, 2013 | 07:33 AM
rockstarbass1's Avatar
Well its been 8 months since I drove my car and last night she finally came alive again. Then I quickly remembered how much my clutch was slipping and got a little sad. Ha I have a 2.2 that I supercharged. I am running an exedy stage 2 clutch and it got a new oem flywheel at the time when installed also. Anyways if put 100k miles on clutches before and beat non them and never burned one out. Is there any chance this can be fixed without replacing a clutch with 40k miles on it? Any chance there is another issue? In know the peddal doesn't feel normal either or like it did new. Bleed the clutch? All I know is I'm never buying a 3 puck design clutch again. And guess I should go with astage 3 . Also I was thinking of buying a LSD while I'm at it doing a clutch. Is it worth it? I guess at that point I'd need axels and some good DR's or slicks though right? It was either that route or new rods cam shaft valve springs and retune. (I dread having to go through the trifecta ordeal again car never has ran how I wish or want)
Old May 1, 2013 | 11:22 AM
dcrep06's Avatar
the trans doesnt already have LSD? and ask around to see how much installing the LSD would be, i do all the work on my cars but i dont know if i would dig into the trans to swap the diff lol. and you wouldnt NEED the axles but they always do help so u dont snap one. if you do a sticky tire then you DEF want to do axle upgrades. and idk the luck other ppl have had with exedy but i have a stage 4 6puck clutchmasters and love it. want to say i have almost 40K on mine and it grabs and goes just as quick as it did brand new.
Old May 3, 2013 | 03:49 PM
SaberD's Avatar
I think ZZP installs a limited slip for like $350 labor.
I'll probably put my own in next summer. I'll be sure to make a thread with the full procedure and plenty of pics since I don't think there is a DIY anywhere on the internet.
factory procedure is here and also in the service manual, but we all know how crappy those instructions can be.
https://www.cobaltss.net/forums/2-0l...rbo-ss-186855/
Old May 3, 2013 | 03:52 PM
Blackbalts's Avatar
LSD's for the 2.2 cost around $1,200 plus your install cost. Just an FYI if cost means anything to you.
Old May 3, 2013 | 03:55 PM
SaberD's Avatar
oh thats right you have a 2.2. I guess the f35 install procedure won't do you much good.
Zharrington_2010LNF
Feb 8, 2016 01:43 PM
brandon04
Oct 21, 2015 07:04 AM
SSLOW06
Oct 1, 2015 07:21 PM
Iceberg
Sep 29, 2015 12:33 PM
Iceberg
Sep 28, 2015 01:31 PM
