Clutch slips
Old Apr 26, 2015 | 12:31 PM
bdeem32's Avatar
Clutch slips
After my engine build I put a brand new southbend clutch and pressure plate in. Stage3. I however forgot to get the flywheel resurfaced, but can't imagine it would slip that bad. it's slipping really bad. I have to drive extremely light on the throttle, and I mean extremely light to get it to go. What could it be? Was installed correctly
Old Apr 26, 2015 | 12:48 PM
Sl0wbaltSS's Avatar
Not torqued down? Well you're gonna need to get a new flywheel now. See if there's and oil or grease getting onto the flywheel causing it.
Old Apr 26, 2015 | 12:49 PM
bdeem32's Avatar
I torqued them all. And I only drove it maybe 15 miles at most
Old Apr 26, 2015 | 07:49 PM
09CobaltSS1's Avatar
First mistake.. Using a brand new clutch with a flywheel that isn't either new or resurfaced is a huge no no.
Second mistake (guess on my part).. The pressure plate wasn't prepped properly, so instead of bedding the disc to the plate, the disc was essentially "lubricated" and has zero chance of ever bedding.
In other words, you need a brand new clutch disc and flywheel. If you're lucky, you MIGHT be able to salvage the disc if you work it correctly.
Old Apr 27, 2015 | 08:18 AM
bdeem32's Avatar
How can I tell if the disc and flywheel is fine? what about pressure plate?
Old Apr 27, 2015 | 09:37 AM
Your disc is screwed. No two ways around it brotha. As far as the flywheel goes, don't even mess with it at this point, just get a new one with all 8 flywheel bolts. I'd have no way of determining if your pressure plate is still good or not unless I saw it in person.
Old Apr 27, 2015 | 09:49 AM
bdeem32's Avatar
Where can I get just a disc?
Old Apr 27, 2015 | 10:23 AM
bdeem32's Avatar
Who knows. Maybe I'll get really
Lucky and itl be fine. The sprockets on the cam gear snapped and my motor was spinning and I didn't. Bend any valves.
Zharrington_2010LNF
Feb 8, 2016 01:43 PM
RaginChopsuey
Oct 27, 2015 01:27 PM
SSLOW06
Oct 1, 2015 07:21 PM
Iceberg
Sep 29, 2015 12:33 PM
Iceberg
Sep 28, 2015 01:31 PM
