Cosmo Short Throw shifter Question
Wat does this blue thing go to that came with it...its like a long blue block and im lost
i put this **** all back together and it wont go in reverse so id imagine this peice is important
Last edited by Sloco Productions; Jan 12, 2008 at 06:56 PM. Reason: Automerged Doublepost
That + the c-clip replace the plastic pin you remove while taking the shifter apart. It holds the plastic lever thing on the side in place.
It sounds to me like you need to adjust the linkage.
ok i figured it out...thnx...now its all together shifts fine(linkage was off)...but now it clicks...its the big white peice that the blue peice goes into thats clicking..i saw in the tmw instructions it said to cut....did i need to cut the parts off?
no i put it back on....i put everything back together correctly...the cup on the big ball and the little on on the little ball...the blue peice is in....idk ill have to pull it all apart again and see whats wrong
