Draining Trans Fluid Question
Old May 20, 2008 | 06:32 PM
mkulrey13's Avatar
So i wanna flsuh my tranny out, now when i fill it up, i leave the top fill bolt open and plug the bototm, pour my fluid in until it starts dribbling out the fill hole? is this correct?
Old May 20, 2008 | 06:35 PM
Sunburst_SS's Avatar
correct...be sure and use some pipe sealent on the threads of the plug bolts...
Fill fluid until it is level with the bottom of the fill hole.....appx. 1.8 qt.
XM15's Avatar
Yup yup yup.
Old May 20, 2008 | 06:40 PM
mkulrey13's Avatar
Awesome, I went to autozone they said they dont make Dex 3 anymore so they game me some Dex something that replaces Dex 1-2-3. I dunno cost me 12$ tho the bastards
Old May 20, 2008 | 06:46 PM
dexron VI right?? that replaces all the other Dexron ATF's for GM
Old May 20, 2008 | 06:47 PM
UmeNNis's Avatar
errr this is the manual right? Use Royal Purple fluid!
Old May 20, 2008 | 06:49 PM
mkulrey13's Avatar
no not Dex 6. Its DEXMERC ATF. Says for 83-05 GM cards requiring DEX 1-2-3 etc.
I have it and it shifts like **** since. Going back to OEM specs to see if it solves the problem.
Old May 20, 2008 | 06:50 PM
XM15's Avatar
My manual said to use Dex III and that '07s and up use Dex VI. I wonder if there is really that big a difference.
Old May 20, 2008 | 06:57 PM
yea, yours calls for dex III......07's call for manual trans. fluild part #88861800......not really sure what the difference is honestly, I don't do much of the transmission work
Old May 20, 2008 | 07:11 PM
UmeNNis's Avatar
Really? Weird... I thought mine felt alot better after swapping out to RP. Is it possible you used the wrong kind? (It's been awhile but I know there are a bunch of different kinds...)
Old May 20, 2008 | 09:02 PM
mkulrey13's Avatar
another question, how the hell do i get access to the drain bolt. My normal allen wont fit, im in the process of grinding it down is there any other way besides dropping it?
Well that was easier then changing oil on the SC cars... took less then 10 mins once wheel was off.
Old May 20, 2008 | 10:55 PM
AzulitoAlero's Avatar
what do you mean dropping it? theres nothing to drop? ohh maybe its diff in a sedan..??
And taking the wheel off of an sc? lol its not THAT hard lol - we found a nifty way of maneuvering the oil filter off in mine It just takes some tools that fit the cap on it and my bf - he has long, skinny hands so its no problemo!
Old May 20, 2008 | 11:38 PM
rrutter81's Avatar
the pic above is from my cobalt ss/sc
I bought an 8mm allen from autozone that was shorter than the ratchet/socket one.
Old May 21, 2008 | 08:45 AM
mkulrey13's Avatar
you need to RE-read what i wrote i said it took 10 mins once the wheel was off to change the trans fluid. It was easier then changing the oil on a SC car. Never mentioned taking the wheel off for oill........ As for dropping it, I was refering to the subframe as my allen key didnt fit till i grinded down the end about half an inch....wow Reading > you
Old Jun 26, 2008 | 10:12 PM
The Factory Man's Avatar
DEXRON VI is far superior to all previous DEXRON fluids and was used in production starting in 2006. It should be used in all GM automatic transmissions that specify DEXRON fluid. If you have a manual transmission that used DEXRON III, DO NOT use DEXRON VI in it. Instead use GM Manual Transmission Fluid P/N 88861800
Old Jun 26, 2008 | 10:14 PM
steddy2112's Avatar
F23 takes auto tranny fluid.
F35 takes regular gear oil
Old Jul 3, 2008 | 10:47 PM
qwikredline's Avatar
no no no. dont do the fill it till it pours out you will overfill it.Bad things happend with too much oil in the trans, measure it in. and use GM fluid (Silkolene 75 w 90 ) that is the best...Fluid capacity (approximate): 1.7L / 2.0 qt ( dry )
DarrenGC
Dec 24, 2021 01:55 PM
Jan 12, 2016 12:01 AM
hacadacalopolis
Oct 28, 2015 06:09 PM
brandon04
Oct 21, 2015 07:04 AM
