Drive Axle reinstall HELP
Old Apr 20, 2014 | 01:00 PM
2010Cobalt's Avatar
im having a little trouble reinserting the passenger front drive axle. I got everything clean and a little lube, the spindle teeth are lined up but im guessing its the little C ring that is probally what is stopping the drive axle from fully inserting. I dont want to bang the C/V joint up so does anyone have some tips on getting the axle back into the tranny?
Thanks
Old Apr 20, 2014 | 01:07 PM
ted5986's Avatar
there is a small dent in the outer end of the axle...use a punch or something that will settle in the dent and hit it with a hammer. firm but dont slip and mess up the end. if you just whack it, you;ll likely mushroom the splines over.
Old Apr 20, 2014 | 02:56 PM
2010Cobalt's Avatar
Are you talking about the cast iron metal after the boot? I've noticed the metal housing around the spline has flat edges that I use to pry it out. Thanks for reply!
Any more tips are appreciated!! Thanks
Old Apr 20, 2014 | 07:56 PM
2010Cobalt's Avatar
Old Apr 20, 2014 | 08:54 PM
SR Tech's Avatar
Deadblow hammer works the best. Soft material so it doesn't damage the threads
Solaris99
28
Mar 15, 2017 01:22 PM
biniecki
Oct 25, 2015 02:23 PM
DANRICKARD
Oct 1, 2015 12:08 AM
importkiller
Sep 30, 2015 07:18 PM
jmelton327
Sep 26, 2015 10:04 PM
