DriveShaftShop Level 5 axles
Old Nov 24, 2012 | 11:48 PM
AyrtonSenna's Avatar
If I have my engine fully build with a turbo kit running a 62/62, trying to put down 600whp or maybe more, would I need to buy those axles or it would be a waste of money?
Old Nov 24, 2012 | 11:56 PM
ryansalazan's Avatar
not gonna say this is 100% but if your lnf then i think the stock axles will still be fine
Old Nov 25, 2012 | 12:08 AM
Are you sure? I don't want to take the chance to have my cat towed home because of an axle failure. Also, are they just stronger axles or they help a little bit as far as traction and wheel hop?
Old Nov 26, 2012 | 12:00 AM
the axles wont help with wheel hop thats what the motor mounts will help with. As far as a definite answer im not 100% sure. I know that I'm currently at 572whp and I'm having to watch my transmission before my axles. The transmission will go before the axles.
Old Nov 26, 2012 | 12:13 AM
EXsoccer1921's Avatar
the dss level 5's are for lsj's. theyre LNF hubs, spindles, and control arms. and beefed up lnf axles. aka LNF stage2 axles.
and 3rd will probably go before an axle. unless you just twist it apart on a launch.
Old Nov 26, 2012 | 12:23 AM
Knightwolf's Avatar
Axles? What have you done to your tranny to handle 600 whp?? I need something before spring too I keep hearing about ZFR's blowing trannies in less than 6 months time.. haven't heard anything about a single axle blowing up.
Care to enlighten me on your tranny solution? :P And any of you high hp guys as well. Not meant as sarcasm either.. I really need/want to know
Old Nov 26, 2012 | 09:51 PM
As far as tranny, I'm getting the zzp tranny when it is time to do the engine.
Old Nov 27, 2012 | 03:51 AM
Omiotek's Avatar
Its kind of funny how people point the finger at specific turbos and increased power for blowing up transmissions all the time. It doesn't matter who's stuff or what the time limit you have the stuff on the car for is. The fact there's increased torque is going to do damage sooner or later. Half of the battle is improper launching, sticky tires, wheel hop, and poor driving. Theres guys that break stock axles on the stock turbos which if you ask me is ridiculous. The lnf axles are beefy as can be. Dss will build anything you want. They build our solstice axles which are good for 1000hp
You need to ditch the ttr ottp mount setup in favor for a full line of ttr or Zzp or Powell mounts. Personally I don't think rotated mounts should be run with a engine mount that limits the rotation of the engine. So to me you pick one or the other.
Old Nov 27, 2012 | 07:37 AM
2010SS's Avatar
I twisted up my driver axle launching on slicks/stock turbo
Old Nov 27, 2012 | 11:23 AM
That's why I was asking
Old Nov 27, 2012 | 01:35 PM
Omiotek's Avatar
they will do whatever you want more or less. does it hurt to upgrade? no but if all your going to be doing is road racing or highway pulls dont even bother with upgrading the axles. 90% of the wear and tear on them is caused from hard launches on sticky tires or improper launching and wheel hop
Old Nov 28, 2012 | 03:43 AM
Nfamous60's Avatar
my boy has put down 626whp on a dyno no tranny mods, but burnt the **** out a piston with a lean daily driver tune. stock axles
Old Dec 5, 2012 | 11:08 PM
Knightwolf's Avatar
Wow.. serious? So a clutch upgrade by itself might hold 500 whp w/o too much problem? I suppose it depends on how well each individual tranny/axle is built too right? Hmmm...
Old Dec 5, 2012 | 11:14 PM
also powerband plays a big part. you can hold 600 all day when it comes in at 5k
Old Dec 5, 2012 | 11:35 PM
JapEatr's Avatar
South Central *********
Power doent break axles, torque and shitty driving does
Old Dec 5, 2012 | 11:37 PM
Omnigear's Avatar
600 @ 2k
Old Dec 5, 2012 | 11:42 PM
i was refering to nfamous's post
chefhhr
Oct 26, 2015 10:36 PM
biniecki
Oct 25, 2015 02:23 PM
DANRICKARD
Oct 1, 2015 12:08 AM
Extremespeed
Sep 29, 2015 04:34 AM
