Dynoed the Harrop, Broke it at the track
Not just dynos, but also the volume versus mass thing. Mass of any specific volume of air is going to change a whole heck of a lot at different temperatures.
But anyway, my point of posting in this thread is:
Has anyone broken a CTI downpipe yet? I haven't seen one break myself, and they are priced very competitively with the ZZP downpipes.
Hey!! I wants mine first!
well, errors in measurement aside,
the point im getting at, is i dont see the reason for such low timing.
just doesnt seem to make much sense.
ive heard rumblings of this issue a few times from other people who have the harrop,
just trying to dig and get all the information i can, as im considering dropping a big chunk of change on one.
I have just about every cooling mod possible and it still runs way too hot
i got cx racing intercooler biggest that will fit, gm dual pass option b
only things left is possbly co2 on the intercooler and co2 on the intake pipe, and killer chiller
and what are your ambient temps?
yeah, its been very warm around here lately too....(cruising IAT2s hovering at 100)
I dont like workin the car hard at all when its that warm,
takes very little to get it into the 140s-150s
well these runs on the dyno were without it (meth), but i have it now and ive seen little improvement
iat1s have been in the 80s and im generally about 40 more than IAT 1 regardless of the temp
#37
#38
how much of a power difference is there going to be going from 11.0AFR to 11.5?
that would give a clearer picture of what ill be making once the tune is cleared up
#39
I can say an M62 car w/ 2.6+meth running 21* (17lbs) pulls noticably harder than a TVS car w/2.7 no meth running *9-10 (24lbs). Both 10:1's and 272's.
From what I've seen these cars like timing more than boost, but with 2 different compressors, eh, can't really make a fair comparison.
#40
Everything I've seen points to the fact that at the same mass of air, the TVS should have cooler air and thus allow better timing and therefore, more power.
#41
Rent me! per hour
if you can cram 25 degree's of timing down the next of the lsj with the tvs. you're onto sometimes. if you can't run more than 12 degree's. you might as well stick the m62 back on it.
#43
I'm running around 16-17* right now, stock pulley, no knock. What do you think a TVS on the 85mm, and the 2.4 would do? You think I'd even be able to run 16-17* on the 2.4, since the cr is a bit high? I want to stick with 93octane. Maybe if I threw some meth at it, it would work well.
#45
well at him.
very interesting
#46
#48
Someone with a built ass motor needs to strap a TVS on, and see what it does!!! Just cramming 24 lbs of boost into a stock head/cams motor is not going to yield exciting results!!!
#50
