Engine making loud knocking noises on startup :(
Old Aug 17, 2012 | 02:34 PM
  #51
toysareforboys's Avatar
Well, cam chain just broke.
Looking for a new engine. If you know of one within a 6 hour drive of Toronto, Ontario please let me know
-Jamie M.
Old Aug 17, 2012 | 02:53 PM
  #52
turbosmart4's Avatar
Crap man a tensioner caused all that crap???
Old Aug 17, 2012 | 03:02 PM
  #53
I wouldn't blame it specifically on the tensioner
I had a cracked piston ring, causing fuel to get into the oil. This makes the oil super runny (it was like water even though I had just changed it when I had the tensioner replaced) which means that it can't push on the tensioner properly to keep pressure on the cam chain. This runny oil also causes your bearings to wear faster, and eventually they wear so much your car isn't able to keep proper oil pressure.
So, runny oil, low oil pressure, worn cam chain and guides, etc. led to a bolt braking and all hell breaking loose under there
The mechanic said he's seen it a TON OF TIMES on cobalts?!?! WTF!!!
Gave me this print out:
Originally Posted by GM
AIP3252
MODELS:
2006-2007 CHEVROLET COBALT, COBALT SS
2006-2007 CHEVROLET HHR
2006-2007 CHEVROLET MALIBU
2007 PONTIAC G5
2006-2007 PONTIAC G6
2006 PONTIAC PURSUIT(CANADA ONLY)
2006-2007 PONTIAC SOLSTICE
2006-2007 SATURN ION REDLINE
2007 SATURN SKY
BUILT BETWEEN 4/1/06 - 11/1/06
WITH ANY OF THE FOLLOWING ENGINES
2.0 ENGINE (VIN P - RPO LSJ)
2.2 ENGINE (VIN D OR F - RPO L61)
2.4 ENGINE (VIN B OR P - RPO LE5)
The following diagnosis might be helpful if the vehicle exhibits the symptom(s) described in this PI.
CONDITION/CONCERN:
On rare occasions, a tick or rattle noise may be heard from behind the front cover of the engine and/or pieces of a timing chain roller may be found during an oil change. This may be the result of a timing chain concern.
Non-heat treated timing chain rollers were randomly installed in the assembly line hoppers. He advised that this happened sometime between 4/1/06 - 11/1/06 so it can randomly affect late 2006 - early 2007 models.
RECOMMENDATION/INSTRUCTIONS:
If this concern is experienced, inspect the timing chain for missing or damaged timing chain rollers. If a missing or damaged timing chain roller is found, replace the timing chain and gears using the part numbers currently listed in the parts catalog.
Please follow this diagnostic or repair process thoroughly and complete each step. If the condition exhibited is resolved without completing every step, the remaining steps do not need to be performed.
They accidently put some non-hardened parts in the automatic feed hopper that our engines get built with!??!
WHAT THE ****!
Looks like I'm calling Sarah from GM back!! I asked her about ANY service bulletins or recalls on my car, and she said "nope", but my f'ing mechanic can just print this out??
Will be interesting to find out what date my engine was built...
EDIT: Says built 11/2006 on the door sticker! hmmmmmmm.
-Jamie M.
Old Aug 19, 2012 | 12:06 AM
  #54
Damn.... I really wish we could get thiss fixd for free cuz mine knocks on startup....
Old Aug 19, 2012 | 12:41 AM
  #55
brian.olsson's Avatar
Damn, that sucks, and I wish I would have been watching sooner, I would have suggested you get a complete timing kit off crateenginedepot. But the thing I don't get is their is nothing fuel related around the timing set that would cause it to leak into the oil from it rubbing on something in the head without getting a bad vacumm leak. honestly, what I think the fuel was coming from cause of the miles you had on it, was when you shut off your car one or more of your injectors were leaking into the cylinder, and past the rings, could the rings have been bad, yes, but I"ve seen gas leak past either way.
But I hope you find another engine soon. and again sorry for your experience with your car
Old Aug 19, 2012 | 08:56 AM
  #56
Follow the advice of the post above this one. Find out the cause, and if it's anything timing chain related, replace the entire timing chain, guides, tensioner, etc. from crate engine depot.
It's better to spend $1k and fix the knocking, then spend $3.5k replacing your engine
-Jamie M.
Old Aug 19, 2012 | 06:14 PM
  #57
Shogokuma's Avatar
im taking the cover off soon to inspect
Old Aug 19, 2012 | 08:58 PM
  #58
Mine doesn't sound too bad though.. only on startup... Ordered a new tensioner, gasket, and bolt to see if it fixes the problem... If not then I wil order a timing chain
Old Aug 19, 2012 | 09:42 PM
  #59
Shogokuma's Avatar
Cobalt SS Supercharged engine noise - YouTube
does it sound like that?
Old Aug 19, 2012 | 09:44 PM
  #60
Yea very similar!
Old Aug 19, 2012 | 11:12 PM
  #61
Shogokuma's Avatar
i have a theory but this noise is actually part of the belt tensionner, but to make the noise it seems like the chain is loose because when it was really loose(bad chain tensioner) that was like 3 times as noisy. i have anew tensione in and now it makes noise on startup so i believe my chain is stretched. causing the idle pulley to not turn smoothly causing the belt to kinds jump around. does this make sense at all or im just going nuts?
Old Aug 20, 2012 | 07:51 AM
  #62
It makes sense; my belt tensioner looks a little lose but it doesn't look like it will get tightened up with the bolt.... I thought it was suppose to be like that... I might have to check later
And by chain stretched u mean belt or actual timing chain?
Old Aug 20, 2012 | 10:41 AM
  #63
Shogokuma's Avatar
acutal timing chain, the only belt on the lsj is the accesory/superchager belt
Old Aug 20, 2012 | 07:33 PM
  #64
Yea I thought u were talking about the belt... But yea, first ill replace the tensioner since mine doesn't sound too bad hope it fixes it
Old Aug 20, 2012 | 07:54 PM
  #65
Powell Race Parts's Avatar
its the chain guides and bolts folks....good luck. CED has a package with everything for small $
-Jamie M.
I got one, try email or the fone...
Last edited by Powell Race Parts; Aug 20, 2012 at 07:54 PM. Reason: Automerged Doublepost
Old Aug 20, 2012 | 07:59 PM
  #66
So even if I just hear it on start up its the chain, not tensioner.?
Old Aug 20, 2012 | 08:12 PM
  #67
it could be the black guide, and the shoulder bolt that holds it breaks and the guide flops around. Or the bottom of the black guide chips and lets the chain get a little bit out of control especially on the over run (decel) I always so complete kits on rebuilds, and ZZP told me they are looking at going to an 8 mm bolt instead of a 6 mm shoulder bolt.
Old Aug 20, 2012 | 08:14 PM
  #68
I e-mailed you on Friday John. I haven't got a reply yet.
Here is what I sent you:
Sent: Friday, August 17, 2012 5:38 PM
To: 'john@powellraceparts.com'
Subject: Cobalt engine swap
Hey John. My 07 Cobalt SS Supercharged engine is sick. It drinks more coolant than it does fuel (not into the oil, not externally, must be burning it), pisses fuel into the oil, and now the timing chain is going/gone (already replaced the tensioner with the updated one 2.5 months ago).
I’m thinking about buying this engine: 04-07 COBALT SS/ION REDLINE LSJ SUPERCHARGED 2.0 ENGINE REMAN/REMANUFACTURED | eBay
Would you be able to swap it for me? How much would something like that cost?
Let me know if you've got an engine for me, or if that rebuilt one on ebay seems good.
Thanks!
-Jamie M.
Old Aug 20, 2012 | 10:55 PM
  #69
Shogokuma's Avatar
i found the top bolt of the black chain guide was completely floating in the whole. making the chain loose and making the guide slaping around
Old Aug 20, 2012 | 10:56 PM
  #70
Nice!!!
I wonder what causes this bolt to break so often??
-Jamie M.
Old Aug 20, 2012 | 10:57 PM
  #71
I already bought the tensioner, cover seal and gasket, and balancer bolt last night... What else would I need? And where can I get bolts from? Tried zzp and no luck
Old Aug 20, 2012 | 11:00 PM
  #72
Good find! Hope mine is like this too and not the chain
Old Aug 21, 2012 | 04:54 AM
  #73
Shogokuma's Avatar
easier way to inspect that bolt is to tale off that bit torx cover on the front cover its a hole specificly to install that same bolt on the top chain guide.
Old Aug 21, 2012 | 07:19 AM
  #74
crate engine depot. I have them in stock special shoulder bolt.
Old Aug 21, 2012 | 07:20 AM
  #75
thats true. shouldda said that. what was i thinking? lol
