engine vibration after new clutch install
Old Mar 8, 2011 | 08:52 AM
black08SS-TC's Avatar
I just installed a new clutch in my 08 ss and now I have a vibration, it vibrates between 1500 and 2000 rpms. Any one else had this problem... I have replaced the pressure plate with another new one and it still vibrates so im stumped!!!
Old Mar 8, 2011 | 10:42 AM
Iam Broke's Avatar
Did you put a lightweight flywheel on it?
Which clutch?
New flywheel bolts?
Old Mar 8, 2011 | 01:46 PM
Stock flywheel had it resurfaced
KY clutch stage 3 clutch six puck
New T.O. bearing
Old Mar 8, 2011 | 01:51 PM
Chevycobaltss3's Avatar
are you sure its not a chatter, only way a clutch will make a vibration is either, the pressure plate is loose, you didnt use a alignment tool when installing the clutch, or you have a loose mount . its hard to diag unless you can tell us a lil more.. did you inspect the clutch before it was installed and flywheel.
Old Mar 8, 2011 | 02:06 PM
It vibrates when in gear with the cluch pressed in parked or driving so it can't be the disc.. it can't be outta alignment cause the tranny shaft keeps it aligned and yes I used the tool.. all bolts are tight with locktite on them also all mounts are tight also..
Old Mar 8, 2011 | 02:13 PM
My assumption would be either its normal vibrations because of the heavy. Holding capacity or the flywheel was turned but warped. Only way i see the clutch going bad is if it were loose some how but i dont see how it would be. Did u inspect it all and all looked good..
Old Mar 8, 2011 | 02:22 PM
Yeah it started after I installed the clutch so its not worn out... they sent me a new pressure plate and didn't help so im guessing a flywheel problem but how do u warp a 3/4 in thick piece of steel by turning it?? And yeah it all looked ok and the clutch doesn't chatter when I ease off of it.
Old Mar 8, 2011 | 02:31 PM
Iam Broke's Avatar
New FW bolts properly torqued to yield?
Perhaps it pulled down crooked?
Old Mar 8, 2011 | 02:40 PM
I re used the stock bolts and yes torqued to spec I cleaned the mating surface and bolts also..
Old Mar 8, 2011 | 04:12 PM
^^^^^ because the flywheel has to be mated 100% to turn they could have been at 95% at a cockied angle and made it warped
Old Mar 8, 2011 | 04:45 PM
That I understand. Why don't it vibrate above 2000 its weird man and very aggravating its not fun pulling them transmissions!!!!
Old Mar 8, 2011 | 04:53 PM
How would I get it checked to see?? Or any one have a stock fw for cheap?
Old Mar 8, 2011 | 06:27 PM
IF YOUR VIBRATING and all looked good on inspection meaning you looked at the friction disc an did a visual and physical inspection then you have somthing loose either a bolt for the flywhel, or the pressure plate... from 1-10 rating how bad the vibrationis give me your honest opinion. Cuz my 8 puck had a vibration all the time and so did my 6 puck, but it went away over time. the vibration felt as if the car was in a low rpm in say 5th gear like tat time of vibration or the vibration of gong over gravel. If so for any of these two check your cv axel bearing or intermidiate shaft bearing. where the axel slips into
Old Mar 8, 2011 | 08:22 PM
The disc looked find and I check everything twice or more. Yeah it feels like its lugging down like u have it in fifth gear at 20 mph... but once u get past 2000 its gone. I just don't want it to ruin the engine
Old Mar 8, 2011 | 08:41 PM
Malaclypse's Avatar
Try balancing the engine and trans mounts.
Loosen the front and rear trans mounts and loosen the bolts for the front engine mount. Then rock the engine and let it settle on its own. Re-tighten all the mounts starting with the two trans mounts.
Re-evaluate.
Old Mar 8, 2011 | 09:35 PM
try this but i think yourissue sir is theno slippage of the disc lol... It sounds like it, since its not a kevlar disc theres not any room for slippage . UNLESS YOU GOT KEVLAR THEN id worry lol.
Old Mar 8, 2011 | 09:49 PM
Iam Broke's Avatar
I have a stock LNF flywheel, but shipping the 45 lb beast would kill anything cheap. lol
Old Mar 8, 2011 | 09:51 PM
i just shipped a lnf stock clutch with the flywheel and it cost me 45$ from cali to like indiana or somthing. wasnt bad, and i put insurance on it, sold it all for 200$ killer deal lol.
Old Mar 8, 2011 | 10:46 PM
06SS ALL DAY's Avatar
clutch chatter = noise... rah rah
Old Mar 8, 2011 | 11:00 PM
YelloEye's Avatar
Sounds to me like your motor mounts are preloaded, there's directions on what order to tighten them all up in the service manuals.
Re-evaluate.
Think its something like this but a tad different.
Old Mar 9, 2011 | 02:55 PM
Iam Broke's Avatar
^^^ When you refer to this, do you mean to loosen the through bolts on the mounts or the bolts to the tranny case? I remember I had a hard time lining up the OTTP S2 mounts to the case itself.
I'll dig into the service manual tonight.
Old Mar 9, 2011 | 03:46 PM
YelloEye's Avatar
You loosen the through bolts so that they aren't clamped down on the metal piece of the motor mount before you begin tightening anything. Sadly I do not have service books any more.
Old Mar 9, 2011 | 03:57 PM
Iam Broke's Avatar
K, thanks! I remember the through bolts are torqued to 74 ft/lbs, I'll check on the order if I find it and post back tonight.
Old Mar 9, 2011 | 07:51 PM
Iam Broke's Avatar
Sub frame install on 3-185 in the '09 Service Manual says...
Tighten the front & rear transaxle mount through bolts in the following order.
- Tighten the rear bolt to 100 N-m (74 lb ft).
- Tighten the front bolt to 100 N-m 74 lb ft).
Old Mar 9, 2011 | 10:32 PM
YelloEye's Avatar
Sweet, so just loosen both of em and then do that. Let us know how that works out for ya man.
