equal length on a 2.2
Old Feb 10, 2012 | 09:50 PM
climb385's Avatar
just like title says, can u put ss intermediate shaft and equal length axles on my 2.2?? trying to lose some of this tq steer, it look like the ss bracket will line up with a 2.2 block
Old Feb 10, 2012 | 10:01 PM
07cobaltLScoupe's Avatar
just changing axles won't get rid of torque steer, you need rotated trans mounts for that. i'm not sure who makes them for the 2.2 thou
Old Feb 10, 2012 | 10:29 PM
climb385's Avatar
The whole reason for equal lengths is to reduce tq steer, it help dramstcly on my past neon when I went to Srt axles, I know it won't get rid of all of it but it would help, I don't have much anyways right now as I'm stock
Old Feb 11, 2012 | 04:39 AM
scagnetti76's Avatar
Unless i miss understand your definition of block, no it wont work. The side gear splines are different between the different trannys.
Old Feb 11, 2012 | 04:42 AM
Diffs....
Old Feb 11, 2012 | 09:44 AM
like i said look into rotated trans mounts, http://www.turbotechracing.com the ss axles will not bolt right up because the fit between the F35 and F23 trans are different (you have the F23) if you have torque steer really that bad check your alignment, i rarely have any torque steer and i'm lowered on eibach pro's, ottp rack spacers, and moog endlinks. besides the rotated mounts in the long run will probably be cheaper and last longer than the ss axles anyway
Old Feb 11, 2012 | 11:45 AM
bluebalt07's Avatar
Powell is the only company that makes rotated trans mounts for the 2.2 I believe
Old Feb 11, 2012 | 12:30 PM
yea you may be right, i haven't looked into them much since i have no need for them right now but i know if anyone made them it will be Powell or TTR. to the OP i would suggest PM'ing quikredline, Powell Race Parts, or Turbo Tech Racing to maybe get a better answer to your question
Old Feb 11, 2012 | 07:05 PM
climb385's Avatar
i just ordered bc coils, ttr rack spacers, ttr motor mounts, going to order the ttr side motor mount soon, so im going to be low, i was just wondering if it was possible, only reason i asked was bc i did the swap on my past 3 neons using srt4 axles, still getting used to the cobalt world lol
Old Feb 11, 2012 | 08:17 PM
yea i hear ya, if you run that ttr set-up you should be pretty good thou...
Old Feb 12, 2012 | 08:51 AM
TurboTechRacing's Avatar
Yeah for the 2.2L engine, get the TTR Upper Mount and Tranny bushing inserts. Wheel hop be gone!
Solaris99
28
Mar 15, 2017 01:22 PM
Stuff
Oct 1, 2015 05:47 PM
Tupp
Sep 30, 2015 08:18 PM
Dylan Johnson
Sep 30, 2015 08:57 AM
goaliemo
Sep 28, 2015 01:37 PM
