Exedy hyper single grinding noise
Ok so my clutch is finally broke in and When i go WOT in first to second i hear this grinding noise it catches but it just sounds like its grinding anyone with a exedy hyper single have this problem. It only happens in first to second at WOT.
If i hold the clutch down for like a extra second or so it doesnt do it or atleast not as loud.
there is no adjustment. any one who says there is well they are liars. How does that make you feel? no other way to say it, the whole deal is hydraulic for release...it sucks that folks get taken by repair places...darkmanx you may have the little stell strap on the side of the bell housing rubbing that happens and stops after a while i dont know why the strap is there... i hope thats it if its more then trouble and that would suck big time
Wow, I'm glad to learn that bit of news.
I'll tell you that the clutch wouldn't engage unless it was on the floor, he rolled it back in, put it on the lift and when it came out I had travel with the pedal.
I just got mine installed 2 days ago.
i have an interesting "rubbing" noise when im engine braking.
im taking it back to the dealer monday to let them listen.
It may just be harmonic vibration from the new clutch + tranny mounts....
but ill let you know.
not really getting any chatter yet. but im going very easy on it so far.
its most noticable when cruising at highway speed in 5th, and letting off the throttle.
sounds almost like a dragging brake would.
its hard to describe.
I've noticed that some of these cars have gear noise when you unload the trans, and only in certain gears in certain cars. Could be what you are getting. Does it go away if you push in the clutch?
serious?
hardly what id describe as a "chattering" sound, though
sure does
sure does
the hyper single chatters. mines done it since day one.
whoever had thier pedal "adjusted"..you probably just had the system bleed. its like a brake system, all hydraulic. in fact, its part of the brake system so to speak, it all uses the same master cylinder. i didnt have any problems with mine and i've had it in for a year at least. its a strong clutch, sucks to drive in traffic jams and with the a/c on though
cuz thats really the only time ive noticed it so far.
