F23 issue
Old Jul 18, 2010 | 11:30 AM
BLKLS's Avatar
F23 issue
So at times when i'm stoped at a full stop, car is out of gear, depress the clutch and put the car into first gear it'll go about half way and stop. If i take it out of first and put it in another gear go back to first it'll go in noproblem. If while its at the halfway point and i begin to release the clutch it'll go in once the clutch begins to grab.
Is first gear syncro'd? Maybe the syncro is going out?
Old Jul 19, 2010 | 06:36 PM
BLKLS's Avatar
Old Jul 19, 2010 | 07:35 PM
07cobaltguy's Avatar
i think its pretty common. mine does it from time to time.
Old Jul 19, 2010 | 08:48 PM
BLKLS's Avatar
Common? Really? Cause it'll happen 6, 7 times on my hour and a half drive home one day and then nothing the next.
Old Jul 19, 2010 | 08:53 PM
lwpmoon's Avatar
Completely normal. There is no synchromesh for first gear so sometimes the teeth of the gears don't line up. If your on a hill and it does that you can literally roll back 1" and it will go into gear or let the clutch out and in again to move the gears again.
Old Jul 19, 2010 | 11:03 PM
BLKLS's Avatar
Ok then, stupid car... I guess i'll deal with it.
Old Aug 2, 2010 | 03:28 AM
slobalt08's Avatar
this is actually mentioned in the car manual. just go to second then back to first and it should go in.
Old Aug 2, 2010 | 11:48 AM
Maven's Avatar
Come on guys First gear is synchronised,(all gears are) and yes this is normal... The reason it wont go in is because synchros cant work if the shafts for the gears arent moving..... So when you release the clutch pedal slowly or allow the car to roll you allow the shafts to move and the synchros can work.
Trav3480
Oct 1, 2015 08:17 PM
Tupp
Sep 30, 2015 08:18 PM
yellow dragon
Sep 28, 2015 09:49 PM
SlowSaturn
Sep 28, 2015 11:03 AM
