F35 Fifth gear removal in 15 minutes
Old Jan 21, 2012 | 09:05 AM
mongorat427's Avatar
Heres how you remove 5th gear in 15 minutes. You need snap ring plyers and one of those cheap Harbour freight puller sets and a true value pin punch. After the cover is removed wipe excess trans fluid off everything . Knock the roll pin out of the shift lever and remove it and the slider. Next remove the snap ring . Now you will have to modify the claws on the puller with a grinder so they look like the pictures. Dont get them too hot or it will break. Pull the whole fitfh gear assembly together. Remove the nut on the small gear and use the same puller to pull that gear also. There you go. It took me longer to modify the puller than to remove the gears
5th gear
Old Jan 21, 2012 | 11:20 AM
JacBlackSS/TC's Avatar
what made you do this??
Old Jan 21, 2012 | 11:27 AM
Parts trans I bought for $100 Need to get it out of the way.
Old Jan 25, 2012 | 11:41 AM
StevoElSupremo's Avatar
oh God, the transmission, the one part of a car I will not go lmfao!
Old Jan 25, 2012 | 11:44 AM
alerosaint's Avatar
^x2
Old Jan 25, 2012 | 11:56 AM
If you need a couple hard to get parts I have them.
Old Dec 9, 2015 | 04:18 AM
ashalle2's Avatar
i know this thread is 6 years old but is it possible to see the pictures again?
Old Dec 9, 2015 | 11:24 PM
firehawk618's Avatar
It's just a gear puller with the jaws ground down so they're thin.
Standard stuff for pulling gears when you don't have much room behind them.
biniecki
Oct 25, 2015 02:23 PM
brandon04
Oct 21, 2015 07:04 AM
Iceberg
Sep 29, 2015 12:33 PM
Iceberg
Sep 28, 2015 01:31 PM
