F35 tranny question
Old Oct 12, 2016 | 06:58 AM
Isaac Lewis's Avatar
F35 tranny question
so the slave cylinder is the same thing as the throw out bearing correct? and is the tranny a linkage or hydraulic tranny? and what other parts should i replace when doing clutch/flywheel?
Old Oct 12, 2016 | 08:23 AM
Tdubbs's Avatar
The slave is the throw out bearing on the F35. The clutch system is hydraulic with cables for the shifter linkage.
Generally, as a minimum when you do the clutch, you should do the flywheel, flywheel bolts(torque to yield), clutch pipe, and the clutch elbow. I went farther and got the pipe from the master to the elbow, and some go as far as replacing the master as well.
Old Oct 12, 2016 | 05:18 PM
ok. you mean the master cylinder line?
Old Oct 13, 2016 | 08:20 AM
Tdubbs's Avatar
Yes. You can get away with no doing it, but since you're there it's just an added "I don't have to worry about it" measure.
Old Oct 13, 2016 | 06:27 PM
exninja's Avatar
QFE
The further away from the transmission, the less of an ordeal to change it but it's still easier. The clutch pipe though is a for sure swap (don't forget the little rubber seal in the distro block). The last thing you want to see is a drip of fluid coming out of your bellhousing and have to take the entire stupid thing apart to fix a little pipe in there.
Old Oct 17, 2016 | 10:14 PM
natedogg2337's Avatar
exninja, can you please elaborate on the little rubber seal that the distro block connects with. i have fairly new everything from reputable shop and just started to leak from that connection. looks like an oring and i have tried replacing oring but still leaks down inside under that coupling where clutch pipe goes through fitting. is there something else that goes with the clutch tube that goes to slave? or is this a special seal and not an oring?thanks for your help
Old Oct 18, 2016 | 11:31 AM
exninja's Avatar
There is a special seal. It sits on the very end of the clutch pipe that sticks out of the bellhousing.
Old Oct 18, 2016 | 02:27 PM
Omiotek's Avatar
Replace the clutch, flywheel, flywheel bolts, clutch puor, throw our bearing, throw out bearing bolts, distrubution block.
All these parts are cheap enough to warrent replacing
Old Oct 18, 2016 | 10:14 PM
exninja, you are my hero! been fighting this leak off/on for the last month. picked up part from dealer, installed this afternoon and the old man wagon is shifting just like it should with no leaks. now back to blowing the doors off of unsuspecting cars. thanks a million!
Old Oct 27, 2016 | 03:53 PM
cw383's Avatar
Would the clutch pipe still need replaced if the throw out bearing were unmolested, as in an engine swap? My clutch is only a year old, so I'm not replacing it during the swap. I know to replace the flywheel bolts, but that was all I intended to do.
Old Oct 27, 2016 | 05:53 PM
exninja's Avatar
If I were in your place, and the pipe is only a year old, I wouldn't touch it. In general, if you're going to leave the TOB/pipe assembly intact, I personally wouldn't mess with it but that's my opinion.
Old Oct 27, 2016 | 08:23 PM
63 Nova SS's Avatar
Me either
alex1/9
Jan 19, 2017 08:09 AM
pommarcin
Oct 5, 2016 09:19 AM
Chris06CobaltSS
Sep 26, 2016 09:32 PM
Sslowbaltian
Sep 21, 2016 01:57 AM
