Final Drive Ratio
Old May 2, 2007 | 06:00 PM
Shovel Man's Avatar
Final Drive Ratio
What's your RPM at speed? Mine is 3000 at 80 MPH in 5th with 2.2 litre. I'm interested in numbers from other 2007 models, auto or 2.4 litre. I want to figure out if I can change something.
Old May 2, 2007 | 06:20 PM
Archie's Avatar
At 80mph in 4th (07 2.2L auto) I'm at 2850-2900 just a tad under 3K.
Old May 2, 2007 | 08:50 PM
HunterKiller89's Avatar
you can actually do the math yourself if you look up the gear ratios and final drive ratio. also, i believe the 2.4 uses the same F23 manual tranny and 4t45e auto tranny as the other balts...i my be wrong though
anway, for any given speed, it would be (RPM/gear ratio)/final drive ratio= wheel RPM
then take wheel circumfrence*wheel RPM*60=speed (in what ever units you used to measure the wheel circumfrence...probably inches or feet)
Old May 2, 2007 | 10:18 PM
Halfcent's Avatar
I'm old school
Old May 2, 2007 | 10:20 PM
HackAbuse's Avatar
~2500 rpm @ 75mph
Automatic 2.2
Old May 3, 2007 | 01:47 AM
my bad...never really considered the differentials would have different ratios between the 2.2 and 2.4
but at any rate, you can still do the math to figure speed@RPM
Old May 3, 2007 | 09:46 AM
Shovel Man's Avatar
Thanks Halfcent, looks like I might be able to trim the RPM a little with an available gear.
06MetallicBalt
Jul 20, 2025 08:47 PM
RaginChopsuey
Oct 27, 2015 01:27 PM
brandon04
Oct 21, 2015 07:04 AM
Trav3480
Sep 28, 2015 02:46 PM
DocSvensk
Sep 27, 2015 02:24 PM
