Finally! I found the solution to bleed our clutches...
Old Jul 18, 2006 | 04:28 PM
StreetDreamz's Avatar
So after a night and half today under the hood of my car I finally found the PERFECT way to bleed our clutch. Standard way that is commonly known way to do it is to put a hose on the bleeder valve and put the other end submerged in a container of brake fluid, pump the pedal a few times, turn the knob, close the knob, let the pedal go, all that jazz. This is pretty much the same, but slightly modified.
Go get a one-man bleeder kit from your local auto store. Put one end of the hose on your bleeder valve (Make sure the valve is only finger tight, but the hose is on good and tight) and the other end on the top of the bottle. Make sure the brake/clutch fluid resovoir is full the whole time you do this, if it goes down a little at all fill it back up to the brim. There is a slight hole just below full that I believe is the baffle that directs fluid into the clutch line. Fill a part of the bottle with fluid just enough to get the hose inside of it under the fluid level then close the bottle and put it above the bleeder valve somewhere so the air bubbles have an easy upward path. Now go pump the pedal a few times and release it. Go under the hood and loosen the valve a little until the fluid starts to flow, you will see lots of bubbles the first time. Let it flow until all the big bubbles really stop coming or the bottle gets full. Then close the valve. Make sure the car's resovoir doesn't get empty. Dump some of the fluid out of the bottle and close it back up, be sure to keep the hose under the fluid level. Pump the pedal a few more times and release it. Go back under the hood and turn the valve until all the little bubbles stop coming, then close it again. If the bottle is full, dump it. Watch the car's resovoir. Pump the pedal a few more times and release it. Go under the hood, loosen the bleeder, let it flow until it's just plain liquid going through, no bubbles, then close it. Make sure the resovoir is good and full then put the cap back on. Pull the bleeder kit out and start the car, pump the pedal a few times, should be decently stiff but not loose. It will engage like 2" from rest now and there will be no need to come anywhere near the floor to disengage the pressure plate.
Old Jul 18, 2006 | 04:31 PM
R33P3R007's Avatar
360 L337 User
man.. that thing needs pics ^^
or some spaces... my eyes are getting all confused. but i think it's good?
Old Jul 18, 2006 | 05:51 PM
RedBaseBolt's Avatar
No offence reeper but weren't u banned?
Old Jul 18, 2006 | 08:19 PM
No offense man, but this only pertains to the SS/RL owners only, not base cars. It's an informational thread only for people who run into this same problem. Leave your problems somewhere other than your keyboard.
Old Jul 18, 2006 | 08:26 PM
hatrickstu's Avatar
sounds good but def. need pics and a few presses of the enter key
Old Jul 18, 2006 | 08:28 PM
Ljavy17's Avatar
yeah, pics please.
Old Jul 18, 2006 | 09:10 PM
Well since I already did it I have no pictures...lol. When you take apart your transmission to replace your clutch, because you will have to, you will see where the bleeder valve is. The rest is pretty easy.
06MetallicBalt
Jul 20, 2025 08:47 PM
MrInsanityWolf
Sep 29, 2015 04:54 PM
yellow dragon
Sep 28, 2015 09:49 PM
Trav3480
Sep 28, 2015 02:46 PM
metroplex
Sep 27, 2015 07:48 AM
