Emco USA have produced close ratio 3/4/5 gear sets for the M35. 1000 bux each set... just fyi....
(Post 5838770)
(Post 5838770)
Originally Posted by MTE
(Post 5838493)
All you guys are just dreaming too high, 7500 rpms!! lol, you shouldn't be putting so much attention at your tranny but to your engine internals, what good is a tranny that can go that high if the engine wont tolerate it? You will also need 500 whp to benefit from 7500 rpms on an aluminum block 4 banger engine, then you'll have to worried about your sleeves taking a shit. Not to mention replacing your seals every 2 months.
Anyways, you know I'm just talking shit right? jaja |
(Post 5838493)
(Post 5838770)
(Post 5838981)
Heres the thing, people with stock turbos do not need a built tranny. I ran a full drags set up twice a week for two years on the stock tranny. Close to 50 1.7 60 foots on it as well. Why make a tranny that is going to be a stock replacement, there are alot of people going to bigger turbos nowadays. All you need for 7500rpms is valvesprings, nothing else. There is nothing to worry about with sleeves either, Also changing the ratios will only mean about a 5 mile per hour change from 7000 to 7500. The stock tranny gear ratios suck period. If there is a guy making new gears but only doing 3 and 4 why not take advantage of this and get the ratios where they should be?
Originally Posted by FF_ace
(Post 5839004)
truth. hows the car by the way?
:guns:
(Post 5839010)
Doing ok, you? This turbo likes to be boosted lol. Going to put in race gas and goto 30psi today I think.
(Post 5838493)
(Post 5838060)
Also if he is remaking 3 and 4 is there a way he could decrease the ratio? Like getting third to end at about 100 if your revving to 7500? and then make fourth at one to one? Not sure if all that means a whole bunch more work or since he is already making new gears if it wont be to bad.
Why don't you get a 4.45 ratio gear set... sounds like that'd be more along your lines. |
the 4.45 is more of a band aid for the shitty gearing. What we would be doing is making more along the lines of the srt gearing. Also why would you like stock gearing? If your going to say because of highway pulls, if you think about it you will accelerate faster with the gearing I said. Get into fourth sooner which being 1:1 will make for a monster. We would have to talk with shep to find out the rpm drop between gears to make sure we wouldn't drop out of the turbos efficiency range to keep the pull hard and smooth. I hate getting into third at 75 and being in it all the way to 130 mph lol. Through a 26 inch tire on it Nd it's now like 140, which is gay lol.
Our gearing has always worked out really well for me. 4th gear is already a monster for me.
You have to remember... I have a 4.05 final, so mine aren't quite as long as yours. |
(Post 5839941)
(Post 5839738)
I would prefer my gear ratios to be left stock. :lol:
Originally Posted by HHRSSouth
(Post 5839961)
Exactly why I have wondered why more Cobalt SS/TC owners haven't swapped out there 3.82 final drive trans for the HHR SS 4.05 final drive trans.
(Post 5839941)
And I am not trying to persuade anyone either, I truely believe this would make for a better overall car.
(Post 5840075)
John Powell has stated that the case on the lnf is stronger than the lsj. That is one reason, I wouldn't mind the 4.05 as long as the diff is LSD and is as strong as the lnf one. The lnf diff is quafe or how ever it's spelled. Bit I deffinitly don't want the 4.45.
^^^^I'm really surprised this option hasn't been explored by Cobalt SS/TC owners already. |
(Post 5840119)
The HHR SS uses the LNF case with a 4.05 final drive. I have quaife (or however you spell it) LSD also :twothumbs
(Post 5840138)
See I didn't know that. Good info. What does thrid do at 7000rpms?
My 4th gear pulls almost as hard as my 3rd gear. Next time i take the HHR SS out I'll let you know, I actually did WOT 2-4 gear pulls today shifting at 7k for a datalog for Vince to fine tune the E35 blend in, but I didn t look at MPH. I just watched the redline between shifts. |
(Post 5840296)
Off the top of my head I have no idea, but I do shift at 7k rpms 2-4th gears.
(Post 5839941)
You have to remember... I have a 4.05 final, so mine aren't quite as long as yours. i like the idea of a six speed i like the idea of a cr 3/4/5. i make my gear charts in excel http://i857.photobucket.com/albums/a...hart405M35.jpg |
(Post 5840844)
i like the 4.45 a lot.i run it.
i like the idea of a six speed i like the idea of a cr 3/4/5. i make my gear charts in excel http://i857.photobucket.com/albums/a...hart405M35.jpg What size tire is this on? |
I would imagine the stock size. But that is a 4.05 ratio which looks like a nice option really.
