First, third and fifth hard to shift into
Old Sep 1, 2007 | 09:00 AM
pjk91's Avatar
Hey guys,
I have a TWM. I put it in myself, and never had problems. 18k miles later, I noticed for the first time yesterday that it was difficult to get into first, third and fifth. Any idea what the problem could be? Something I need to adjust? Did I void my transmission/clutch warranty with a short shifter?
Old Sep 1, 2007 | 09:17 AM
REIGN SS's Avatar
Original Hayden Fanatic
there is no warranty on your clutch, and for them to void doing warrenty work they have to prove that the aftermarket part caused the problem.
Old Sep 1, 2007 | 09:50 AM
InfinityzeN's Avatar
Crack it open and take a look. Something might have come loose and be causing the problem. Though just making sure everything is connected and tightened down might fix your problem, you might want to consider pulling it out and reinstalling to make sure everything is lined up right. Things shift with time and I'm going to guess that the shifter slide a bit or one of the connections came loose.
Old Sep 1, 2007 | 10:53 AM
pjk91's Avatar
Actually first isn't giving me a problem, only when it's cold which is normal. So it's third which is slightly difficult and fifthe which is twice as difficult. It also feels like fifth adjusts itself when I stick it in.
Old Sep 1, 2007 | 11:03 AM
RA122324's Avatar
Why don't you just pull some panels and take a look at the shifter. Reconfigure it to stock and see what happens.
Old Sep 1, 2007 | 11:21 AM
pjk91's Avatar
Didn't keep the stock shifter. I'll take it apart tomorrow when I'm off from work and see what's going on under there.
Old Sep 3, 2007 | 05:47 PM
Brandon97Z's Avatar
check the shift cables where they connect to the shifter and the transmission. I broke a retaining clip on the transmission side of one of the cables.
Old Sep 3, 2007 | 07:46 PM
pjk91's Avatar
I broke a piece that was plastic, shaped sorta like a T and it had a bearing inside it. I even went to the dealer to find out what it was and they couldn't tell me. So I went ahead and used the shifter without it. Worked fine in every gear. Then, after 18k miles this. It hasn't got any worse or better since I first notcied it and it's going to the dealer just for them to check. Let ya know whatsup tomorrow.
Old Sep 5, 2007 | 09:26 AM
pjk91's Avatar
Dealer won't break open the tranny unless I have a stock shifter on there. They said as far as they can tell, the shifter is causing it. That doesn't make any sense though, since it's been on the car for so long and I basically drive on the highway 90% of the time. So I don't do much shifting.
Anyone have a stock 2.4 shifter laying around? I'll pay shipping and if you want it back...I'll pay for it to come back too.
Old Sep 5, 2007 | 09:29 AM
R&C_rallySS's Avatar
Originally Posted by pjk91
Hey guys,
Good luck with that...just got back from my dealer. They told me my clutch went out because of my short B&M shifter. They told me they would normally cover it because of how low my miles are but in this case I have an aftermartket shifter. I just at them and told them to give me the keys back. Told them I will not be paying for them to look at it. I'll just do the clutch/flywheel myself. When GM calls me today they will be getting a nice ear full of how I feel. I can't wait....haha a clutch going out because of the shifter knob ******* GM
Old Sep 5, 2007 | 04:49 PM
Brandon97Z's Avatar
Dealer blamed my TWM for the trans popping out of 2nd gear. replaced the shifter w/ a stocker and still did the same thing, yet i still had to pay for it
Old Sep 5, 2007 | 08:18 PM
pjk91's Avatar
if you don't mind, how much was that repair?
Old Sep 5, 2007 | 09:56 PM
Brandon97Z's Avatar
shifter cable=133.56
shifter assembly=221.75
labor for those two installs=245.88
Old Sep 6, 2007 | 08:29 AM
pjk91's Avatar
geez. not looking forward to that.
Old Sep 6, 2007 | 06:50 PM
Brandon97Z's Avatar
Yup bring the KY.
btw I still got that shifter hangin around
Old Sep 6, 2007 | 07:59 PM
pjk91's Avatar
I'll keep you updated. Had to buy books and software for my final semester at SNHU ($990) and new tires because I failed state inspection on one tire ($650) which just about cleaned me out.
Old Sep 6, 2007 | 08:01 PM
an0malous's Avatar
one of your cables has slipped.
the fact that its all of your "upward" gears in your shifter gives it away.
crack it open and adjust it back. 10 minute fix tops
Old Sep 6, 2007 | 08:06 PM
Jimmys2007CobaltSS/C's Avatar
damn bro where do u get that kinda loot when ur still in skool?
Old Sep 7, 2007 | 06:43 PM
2K5SS/SC?'s Avatar
Check your shift linkage. Specifically the parts near where they connect to the trans. If the black plastic sheathing in that spot is cracked or broken, those gear will be extremely hard to get into. New linkage cost about $110 from the stealership.
Old Sep 8, 2007 | 08:03 AM
pjk91's Avatar
I haven't followed the cable to the tranny yet but I did pop open the console and there wasn't anything out of the ordinary.
Old Sep 8, 2007 | 09:44 AM
2K5SS/SC?'s Avatar
Check near the tranny because that is where mine broke at.
Old Sep 8, 2007 | 11:50 AM
pjk91's Avatar
Is that easier to get at from underneath the car? Never worked on transmission before.
Old Sep 8, 2007 | 12:46 PM
Flash~SS2.4's Avatar
Instead of taking it all apart. Look on the tranny where your shifter links, sometimes theres a coolant hose that may drop in to the path, causeing 1st, 3rd, and 5th hard to get into, as the shifter will squish the hose.
Old Sep 8, 2007 | 01:23 PM
pjk91's Avatar
Will I be able to see that from underneath?
Old Sep 8, 2007 | 06:58 PM
pop the hood. facing the car its on the right side between the enging & firewall. You could get some one to move your shifter around while your looking so you could see it. but from above would be eaziest.
thats what i had happen to mine after getting it back from the dealer
