Flywheel questions LNF vs LSJ
Old Jul 19, 2011 | 12:44 AM
ronn's Avatar
1) what's the difference between LSJ and LNF Flywheels? I know LNF costs 3X as much!
2) can you swap an LSJ flywheel into an LNF clutch KIT (PP/disc and TOB)?
BTW.. I see ZZP sells the LSJ and LNF flywheels for the same $$??? Looks like they're the same??
Old Jul 19, 2011 | 01:07 AM
chood711's Avatar
i know that the lsj upgraded clutch is just the lnf stocker..so that tells me they can be swapped. as far as it being the same flywheel or not i cant tell you.
https://www.cobaltss.net/forums/2-0l...erence-150915/
https://www.cobaltss.net/forums/driv...change-236661/
see if these help ya
Old Jul 19, 2011 | 01:16 AM
SlowCobaltSS's Avatar
I know someone that put a LNF flywheel and clutch on his LSJ and all he need to get was longer flywheel bolts or clutch bolts I dont remember which bolts he said
Old Jul 19, 2011 | 01:37 AM
hungryhip-ccp's Avatar
I have a used LNF flywheel, clutch disc, tob and PP in my LSJ. i bought it instead of the gmpp like said ^ its the same ****.
But do not use a lsj tob with lnf. it will not nls right and the lnf tob is far superior than the lsj.
Old Jul 19, 2011 | 08:29 AM
Iam Broke's Avatar
LSJ flywheel is much lighter ronn, LNF is ~45 lbs. I have a slightly surface rusted LNF flywheel in the attic if anyone needs one. Used LNF clutch & slave also with ~20k miles on it.
Old Jul 19, 2011 | 11:37 AM
freakta's Avatar
how much does the lsj one weigh? id love a heavier flywheel
Old Jul 19, 2011 | 12:19 PM
Iam Broke's Avatar
Not sure, maybe around 20 lbs for the LSJ? Just a guess. Hopefully someone knows.
If I remember right, the LSJ GMPP clutch is an LNF pressure plate with an F40 disc, not an LNF setup.
Old Jul 19, 2011 | 12:59 PM
BLue NoTe's Avatar
Just replaced my (cracked) LSJ flywheel, yeah its probably 20 to 22 pounds. Love my 8 pound Fidanza
Old Jul 19, 2011 | 06:24 PM
ronn's Avatar
Ok..so that's it...the weight difference. I assume they're the same size though.
Thanks.
Old Jul 19, 2011 | 07:53 PM
BLue NoTe's Avatar
Engine load = turbo boost. The higher load of the LNF flywheel increases combustion pressure, thereby increasing exhaust pressure and turbo spool
Old Jul 20, 2011 | 01:38 AM
ronn's Avatar
Good point!
Old Jul 20, 2011 | 09:03 AM
freakta's Avatar
and the heavier the flywheel the more low end tq
Old Jul 20, 2011 | 02:54 PM
ATLsilverSS's Avatar
isn't there something different with the dowel pin?
Old Jul 20, 2011 | 05:05 PM
Iam Broke's Avatar
You might be thinking of a SPEC PP on the stock FW, the dowel holes have to be bored out to 12mm on the stock FW.
ineedacobaltss
Nov 7, 2015 02:25 PM
brandon04
Oct 21, 2015 07:04 AM
Sep 27, 2015 08:53 PM
jas09ss
Sep 26, 2015 01:06 PM
Coballin13
Sep 25, 2015 08:43 AM
