Flywheel Difference
Old Jan 15, 2009 | 10:07 PM
Matt M's Avatar
Flywheel Difference
Is anyone familiar with the differences between the flywheels from LSJ to LNF? The LSJ flywheel is just over $100, while the LNF flywheel is a little over $550. That's a pretty big difference, so I'm assuming some improvement was made.
Any info would be appreciated!
Old Jan 17, 2009 | 12:00 AM
Matt M's Avatar
Anyone?
Old Jan 17, 2009 | 12:08 AM
1WhiteSSTC's Avatar
werd, the LNF flywheel and clutch i do believe to be larger than the LSJ one which would be one reason it costs more tho your numbers seem WAY off. Links?
Old Jan 17, 2009 | 12:19 AM
ls1fbody's Avatar
Haz l33t wheelz.
i believe the clutch/flywheel combo that GM sells as an upgrade for the LSJ is just the SS/TC compnents. It probably has something to do with being much stronger to handle the no-lift-shift abilities.
you should buy one of each and build a contraption to do load tests for clutches.
Old Jan 17, 2009 | 01:02 AM
Matt M's Avatar
Originally Posted by 1WhiteSSTC
werd, the LNF flywheel and clutch i do believe to be larger than the LSJ one which would be one reason it costs more tho your numbers seem WAY off.* Links?
I was just going off GM Parts Direct pricing.
That could probably be incorporated into an engine dyno, but I'm betting it would be extremely expensive!
Old Jan 17, 2009 | 10:16 PM
SuperchargedSS's Avatar
lnf clutch feels much stronger than my old lsj
Old Jan 17, 2009 | 10:31 PM
Baldturbofreak's Avatar
The LNF flywheel is a dual mass variety designed to take low frequency oscillations out of the drivetrain. Just like my LT1 vette. Weight 55lbs like my LT1 vette too.
Old Jan 18, 2009 | 11:03 AM
Another + for the TC
Old Jan 18, 2009 | 11:50 AM
SSdan's Avatar
I'd rather have a light flywheel than that heavy ass one.
Overall the LNF has a much bigger clutch than the LSJ.
Old Jan 18, 2009 | 12:18 PM
DGAF260's Avatar
55 pounds is alot for a daul mass flywheel in FWD my svt focus was only 33 lbs and if thats the case changin the flywheel would make a huge difference in performance.
turbochargedss2012
Sep 20, 2023 12:17 PM
biniecki
Oct 25, 2015 02:23 PM
Oct 13, 2015 09:32 PM
jas09ss
Sep 26, 2015 01:06 PM
