full mounts or inserts
ok so like it says, which is a better idea? should i buy new mounts with the polly inserts, or just get the inserts? has anyone put a polly insert in the plastic front trans mount? will it hold up to mild abuse? i have a press to use so that isn't an issue i'm just wondering if the plastic one will hold up really.
I've got and 07 LS with the Prothane inserts on the front plastic mount and the rear metal mount with 8000 miles on them.
Beating the hell out of them for autocross.
Work great, no problems. 50 bucks cant beat it.
I see no reason to do the upper on mine.
lol yeah right after you said that i went and checked the car and wtf it was still there! pulled that sucker out, the car pulls so much harder now! lol
the leaf i mean
the leaf i mean
Last edited by 07MetallicSC; Aug 28, 2007 at 04:55 PM. Reason: Automerged Doublepost
It's like anything, if you take your time and do it right you will be fine.
inserts should be fine...idk about the plastic mount , but its been said to hold up, buy the inserts , if you dont like it or the mount breaks , then get the new mounts and put the poly inserts in them, that way you dont loose any money
thanks for the reply's. i have filled mounts on my old car and didn't have any problems but never intended to do that to this car. i think i'm gonna just get inserts its cheeper, if i break it, well then ****, lesson learned
I've onlt see one plastic mount break and that was from a parking lot stopper that got run over. You'd have to do something really nuts to break it with just engine power. I'd make a farily safe bet you'd bust the clutch first before that mount would go.
