funny noise when releasing clutch when downshifting...
Whats up guys, i have noticed over the last couple days that when i release the clutch while downshift at lets say 2k rpms it is making a weird noise and i feel a slight vibration in the shifter while it makes the noise. it only lasts until the clutch is completely engaged. just for that split second. the clutch feels as good as it always has since the break in was over. i have an exedy hypersingle. any thoughts appreciated....
Sounds like clutch chatter. With an aftermarket clutch, you should never be close to the 2k range. You should be 2.5k at least or higher.
You did loctite the clutch plate on and the flywheel bolts, right?
yeah thats the sound..except not as loud and on last until clutch pedal is all the way released.
DANRICKARD
Oct 1, 2015 12:08 AM
