Gear oil/trans oil
Gear oil/trans oil
well im in the proccess of changing my clutch for the first time and i just removed the axles and trans oil starting coming out.. I would like to know how many quarts of trans oil needs to go in once fully drained and where do i put the trans oil in at? is the tranny oil the same as the gear oil? if they are different where do i put in the gear oil? PLZ HELP
Same trans as the LNF. F35
https://www.cobaltss.net/forums/show...3&postcount=11
The LNF trans fluid is a good upgrade for the LSJ. It takes around 1.7 qts. Fill through the top plug shown until it overflows a bit. 8 mm hex wrench does the trick. LNF fluid is around $26/qt. though.
I couldn't find the LNF GM fluid when I needed it so I used Red Line GL-4 MT-90 & MTL to get the right viscosity. 1 qt MT-90 and .7 qt MTL
Our trannys don't need GL-5 or 5+ as our LSD's aren't the type that require it. OEM fluid is GL-4
Back in the day the recomended manual transmission oil change was never. There was none. If it was quality oil to begin with and nothing obviously broke inside it would get better as it worked. Like I said. Back in the good old days. I don't have my book with me right now but I don't thing\k there's a service required on late models, like ours, either. But I may be wrong.
