Gearbox chatter - best fluid to quite it down?
Old Jan 17, 2012 | 11:39 AM
R1600Turbo's Avatar
My '06 Cobalt LS has a fairly noisy transmission while driving at lower speeds. This is a nice chatter noise from the gearing. Anyone else have this issue, and is it possible to quite it down some by changing the fluid?
Any recommendations on specific fluid?
Thanks.
Old Jan 17, 2012 | 11:48 AM
its probably just from the cold, ur manual right? sounds kinda like when ur in revese?
nm on the cold ur in AZ haha
Last edited by riceburner; Jan 17, 2012 at 11:48 AM. Reason: Automerged Doublepost
Old Jan 17, 2012 | 12:10 PM
StevesBlack06's Avatar
redline mt90
Old Jan 17, 2012 | 01:13 PM
R1600Turbo's Avatar
It's been fairly chilly lately in the mornings. But yeah, manual trans and it's mainly in the lower RPM's.
Old Jan 17, 2012 | 10:12 PM
Sharkey's Avatar
Originally Posted by StevesBlack06
redline mt90
and that will make shifting very hard, almost impossible to get into gear, and burn the syncros up. he has an ls, that will have the f23, not the f35. the 2 transmissions take different oil
the correct fluid for the f23 is automatic transmission fluid, specifically dex 3. if you want to find an aftermarket synthetic fluid, feel free, just make sure its a replacement for manual transmissions that use atf.
Old Jan 20, 2012 | 01:43 PM
R1600Turbo's Avatar
So Dex 3 for manuals.
Got it.
Old Jan 20, 2012 | 09:47 PM
Sharkey's Avatar
dex 3 for the f23 transmission, thats in the 2.2/2.4l cars. the f35 in the 2.0l cars is specific gm fluid.
Old Jan 21, 2012 | 01:15 AM
Malaclypse's Avatar
You won't quiet up that gear rattle. Its just not going to happen. There has to be some clearence in the transmission for it to work properly without melting.
Also Dexron 3 is no longer available. Dexron 6 will work just fine though.
Old Jan 21, 2012 | 01:28 AM
DiabeticKripple's Avatar
i just used stock ac delco **** my brother got for basically free.
Old Jan 21, 2012 | 02:03 AM
Sharkey's Avatar
gm no longer licensed the name dexron 3. there was no point once dexron 6 came out, thats all gm sells for automatic trans fluid. however dex 6 isnt a complete replacement for dex 3. for most applications it works, however it doesnt work in some manual transmissions and gm came out with a manual transmission fluid that was nothing more than dex 3 with a different label. the reason for this is dexron 6 is quite a bit thinner and will cause lube problems in some manuals. there are still many "aftermarket" transmission fluids that are dexron 3/mercon rated, its still the most commonly used atf out there. you will be able to find it at any parts store.
Old Jan 22, 2012 | 04:52 AM
R1600Turbo's Avatar
This is the first car I have owned that has a transmission that makes this much racket. It's also the first domestic car I have ever owned, so maybe that has something to do with it. All my Nissans & Mazdas never chattered this much. I just figured maybe a better fluid than what it comes with from the factory might help. That's usually the case with any other car I've ever driven.
I'll just try a fluid flush with the stock stuff and if it doesn't quiet down, then I'll just chock it up as normal. (yet annoying)
Old Jan 22, 2012 | 01:17 PM
Sharkey's Avatar
did you buy the car used? how long have you had it? has it done this all along?
you may want to take your car in and have it looked at. if its under warrenty take it to the dealer, if not, find a local transmission shop and take it in and have them look at it. its very hard to diagnose things like this over the internet, it could be something normal, it may be something worn out or broken.
Old Jan 22, 2012 | 01:32 PM
montecarloman's Avatar
NO!
Dex 6 has additives in it that will eat the syncros. GM does still offer dex 3 but it is in bottles and its not called dextron 3. Its manual transmission/transfer case fluid, any GM dealer should in stock it.
Old Jan 23, 2012 | 06:51 PM
R1600Turbo's Avatar
I bought it from a small used car dealer, definitely not under factory warranty but it does have a warranty from where I bought it. I'm not worried about it failing, they should replace it. If not...well then they can have their car back.
DarrenGC
Dec 24, 2021 01:55 PM
Tupp
Sep 29, 2015 11:07 PM
Sean Cummings
Sep 11, 2015 09:35 PM
matthewwalsh1994@gma
Sep 10, 2015 10:48 AM
Jacque8080
Sep 9, 2015 09:21 PM
