genuine saab short shifter adaptor.
I will see what I can do, he isn't online much but he works at the saab place that sells them. I know you have to cut the bottom of the shifter off to make it work so some may be weary of that idea.
i figured it went on the bottom when i saw the set screws on it, but wasnt too sure where it'd go on there(didnt know you would need to cut the stocker)
make sure you guys do a picture how to. im a visual guy.
base bushings arent bad at all to do. i reccommend taking the center console out or at least have it loose so you can lift it up to work under it because if you drop one of those or a washer under the carpet im sure its a pain in the ass to get out. luckily by doing that it never happened and im glad i did it that way for that reason.
I installed mine yesterday. I used a combination of the twm instructions and the one that came with the adapter. I found the install to be pretty easy that way. If I had to estimate I would say it shortens the throw probably around 20% or so. You can definitely feel the difference. With the price only at ~$55, I think it's a great deal compared to paying over $150 and upwards of $250 with twm. Overall I am very satisfied and would recommend it.
Sorry no pics.
You will have to cut just above the ball on the shifter, leaving about 5/8" of steel left to slide on the adapter. I used a cutting wheel with my air compressor...took about a minute.
Seriously guys, this was an easy install. I was a little worried at first as well, but once I got into it was very easy. Just be careful when removing the torx screws. I dropped one and almost lost it.
BTW... on the way into work this morning I really noticed a difference shifting into 2nd gear...it is much quicker and easier. The Stock 1st to 2nd sucked in my opinion.
Use the TWM instructions as a guide to get everything apart and put back together and you will be fine. The instructions are on CSS.net somewhere.
