getrag f23 rebuild guide
Old May 24, 2009 | 10:50 PM
nonSS's Avatar
I was just wondering if any one here knows where to get a full rebuild guid for the f23, i have searched but all i can find is specs, and i cant find any part numbers, the reason i'm asking is bc i have a f23 sitting in my garage and i would like to rebuild it and sell it or use it maby lol idk, but thanks in advanced and its a 07 f23 if that makes a diff
Old May 24, 2009 | 10:53 PM
sick06cobalt's Avatar
new idea in mind john?
Old May 24, 2009 | 11:42 PM
Sharkey's Avatar
whats wrong with it??? if there is anothing more than a slight grind your going to put more in parts into it than you will sell it for.
Old May 26, 2009 | 12:56 PM
nonSS's Avatar
3rd and 4th gear syncronizer is toast just prob just need some gaskets and the syncro but i want to check all the gears and make sure every thing is done right, and i might have a idea or 2 david, just gotta get some info to know more about what i'm doing.
12 bump
Old May 26, 2009 | 09:22 PM
Sharkey's Avatar
if its grinding in 3rd and 4th, suspect the syncronizer assembly ( 3/4 hub, sleeve and blocking rings), and have a good look at the 3/4 shift fork, look for any signs of wear.
aside from that, you will need a seal kit (axle seals and the front cover), everything else is siliconed together.
Old May 27, 2009 | 07:57 PM
nonSS's Avatar
i figured thats what is wrong but i still need like a guid on how to check and rebuild it properly
Old May 27, 2009 | 09:43 PM
Sharkey's Avatar
the best thing i can suggest is to go to www.alldatadiy.com and get a subscription. iirc, for $20 you can look up one vehicle and have access to it for an entire year. this is the same thing i have access to at my shop, although we have pro and can look up as much of any vehicle.
Shanman
ZZ Performance
43
Aug 26, 2016 08:43 PM
Trav3480
Sep 28, 2015 02:46 PM
TheSandMan
Sep 20, 2015 06:02 AM
medic710
Sep 6, 2015 08:53 PM
