GM LSJ Upgrade Clutch
It's time to replace my clutch. Who of you are using this and would you recommend it?
Should I get a new flywheel? Is there anything else I should add to my CED order that should be replaced at the same time to save labor costs down the road?
Ecotec LSJ Clutch Upgrade Kit 19212712
I got a new clutch pipe, flywheel, bolts, LNF shifter bracket, and oil to change the tranny fluid.
I just put one in a few months ago. Great clutch, fits perfect. I also did new flywheel, figured might as well. Need new bolts for everything, as well as a reverse torx bit for the pressure plate bolts. We had to drive to the store and buy a set in the middle of the job.
Need TOB, clutch pipe, tranny fluid, all bolts. We did it in 1 long ass day!
plenty of people are running this clutch with no problems get new flywheel bolts and pressure plate bolts you can have your old flywheel turned
post questions like this in the driveline section
LSJ Shift Cable Cable Upgrade Bracket 55563732
That's the shift bracket. Super easy to do when trans out. Get what is mentioned above. I just did mine a month or so ago. I got trans fluid, bracket, axle seals, flywheel bolts, clutch pipe and gm clutch kit. Just had a spare flywheel resurfaced before hand. Was done in a day. Bleeding is a beotch!!
Done this kit in two of my cars already.
I did the same as above. All necessary maintenance and some preventstive. I beat on the car pretty good and this clutch just loves it.
It doesnt kill your leg in traffic either.
I only did axle seals on mine because they were both leaking and easier to do while out. If yours are good just lube up the seal before putting the axles back in to not damage it like Mr b mentioned.
And yes 2 seals.
And yes 2 seals.
This is info I was looking for as well. It's not out there. Some people are holding over 425 on it, but no one ever comments on how many miles.
Most people seem to say the tune has a lot to do with it
Get a good tuner boost ramp is your clutch and trans best friend especially on the stock turbo
Just like the very similar stock lnf clutch they are pretty tough
I upgraded and went with the gmpp as I had problems right as I bought the car. The gmpp will hold a fir amount of power and holds very well for me being stage 3 full bolt ons..I ordered mine at the dealer and had the clutch pipe installed too..You will be happy with gmpp
Sorry to bump an old post but I'm about to order my gmpp clutch, and I read through this and saw that some people had the stock flywheel turned, and had problems with clamping force. I have two used stock flywheels, and would rather turn one than buy one, if I can. That being said, how much machining is too much?
Not necessarily. If they take off too much you will have the same problems.
