GMPP clutch upgrade
GMPP clutch upgrade
does this come with everything to do a clutch swap??? i noticed it just says clutch upgrade so im assuming u need other parts
Ecotec LSJ Clutch Upgrade Kit 19212712 - Crate Engine Depot
it says this in one part::
Package contents:
Item Description Quantity GM Part Number
1 Pressure Plate 1 5337571
2 Clutch Disc 1 5448436
3 Bearing, Clutch Actuator (throw-out) 1 24242805
4 Clutch Pressure Plate Bolts 6 90470712
then this a little below it
LSJ Clutch Upgrade Kit Service Parts List:
Part Number Quantity Name
90470712 1 Clutch Pressure Plate Bolts
24242805 1 Bearing, Cutch Actuator
and for instructions it said look at some manual which i dont have
Package contents:
I believe there is a cluctch alignment tool needed, a new clutch pipe, flexplate, and flexplate bolts needed...
You can skip the clutch pipe, but it's $8 and, if your leaks, you have to tear it totally back down.
You can resurface the flexplate it is isn't too bad.
Also order the clutch line and alignment tool that are mentioned, you will also need those to do the install.
Just order a new insert for your flywheel and you should be good to go.
