H E L P !!!!!
Old Aug 2, 2008 | 02:15 PM
ls1fbody's Avatar
Haz l33t wheelz.
H E L P !!!!!
i didn't know where else to put this.
Im installing my Hurst short throw, how in the F do i get the stock ball off? i took out the screw in the top, but i can't get it to budge, and it's destroying the reverse lockout.
Old Aug 2, 2008 | 02:17 PM
sick06cobalt's Avatar
There is a how to.. search...
jimbos'ss's Avatar
post pics of where your at in the install, and i can talk you through the rest.
Old Aug 2, 2008 | 02:18 PM
https://www.cobaltss.net/forums/show...hlight=shifter
Old Aug 2, 2008 | 02:21 PM
ls1fbody's Avatar
Haz l33t wheelz.
i looked at the how to, and it' all straight forward, i just can't get the ball off. jimbo. i don't have a camera right now, but i took the whole stick/boot/console out of the car. right now i have the stick in a vise and i'm tryig to pry the ball off. does that help any?
Tazmanian_Dvl's Avatar
take two straight screw drivers (one on each side) and work them between the bottom of the stock shifter ball and the top of the reverse lock out lever and work the shifter ball off. It's tight at first but it comes off...
Old Aug 2, 2008 | 02:23 PM
ls1fbody's Avatar
Haz l33t wheelz.
i'll try that see what happens
Old Aug 2, 2008 | 02:24 PM
SlowBalt_06's Avatar
i had to break off that plastic top and makesure you take that screw out of the top..then i just stuck a flat head screwdriver on the bottom side of the shiftknob and wacked it with a hammer
Old Aug 2, 2008 | 02:25 PM
ls1fbody's Avatar
Haz l33t wheelz.
ok, the two worked used no effort at all. why is one so hard?!?! haha
thanks for the help guys.
jimbo, the coilovers look great. autobacs did an awesome job on leveling them out. plus the guys there were kinda mesmerized by a supercharged cobalt, they thought i did it all myself, didn't realize it's mostly stock, haha
Old Aug 2, 2008 | 02:31 PM
jimbos'ss's Avatar
so is it the shift knob thats stuck on or the pivot ball? if it's the pivot ball that stays with the old shifter seeing as the hurst comes with a new one. if i remember correctly you have to do a little bit of assembly with the hurst shifter. if your having problems getting the pivot cup off, just pop it off, it won't hurt it.
EDIT: sounds like you got it
haha, thats cause the last one they seen was turboed.
Old Aug 2, 2008 | 02:35 PM
Not sure whether the "HowTo" covers this but this is how you want to adjust the shifter when you put it in if your reverse lock out and 5th gear are out of alignment (I'm 99% sure they will be). Here's a post I made on another thread...
Originally Posted by Tazmanian_Dvl
OK so I went out and took a picture of the cables for everyone and this is the cable you need to adjust (circled in red)...
Take a sharpie marker and mark the shaft of the cable directly in front of the white connector I have circled (Gives you a reference point to go back to if it gets worse or you want to go back to the stock shifter). The pull up on the tab at the front of the shifter and you can then move the shaft of the shifter cable in and out without moving the shifter. In my case 5th gear was way far to the right when compared to the other gears and 5th gear lock out still worked but the cable was stretched to the max. I moved the cable only about 1/4 out of the connector and locked it and tried it out and it was pretty much perfect. If you have problems with how it sits front to back you would basically do the same thing with the other cable until it was in the position you desired (I didn't have to adjust front to back travel when I installed mine). I would only do adjustments in 1/8" increments so that you don't adjust it too far the other way. Well I hope this helps...
Old Aug 2, 2008 | 03:04 PM
ls1fbody's Avatar
Haz l33t wheelz.
well, i marked the gray one when i took it out, and everything works, including the reverse lockout. now, 5th is a little hard to find because it's not all the way over anymore, but it all works good, feels solid.
haha yeah, that may be it.
it was the shift knob that was stuck, but it's all in now, and together. feels good. TIME FOR A TEST DRIVE!
Old Aug 2, 2008 | 03:06 PM
I love my Hurst shifter!!!!!
Old Aug 2, 2008 | 03:25 PM
jimbos'ss's Avatar
and some new pics with the car leveled!
Old Aug 2, 2008 | 03:28 PM
x2!!
Old Aug 2, 2008 | 03:53 PM
ls1fbody's Avatar
Haz l33t wheelz.
haha, thanks guys, i gotta get a camera first.
Old Aug 2, 2008 | 04:03 PM
Doc's Avatar
Doc
I'll sell you one
Old Aug 2, 2008 | 05:10 PM
ls1fbody's Avatar
Haz l33t wheelz.
haha, what don't you have for sale?!!?
Old Aug 2, 2008 | 08:58 PM
jimbos'ss's Avatar
borrow one dammit, and what soldier these days doesn't carry around a point and shoot camera?!
Old Aug 2, 2008 | 09:18 PM
Doc's Avatar
Doc
women...they are all on assignment
Old Aug 2, 2008 | 10:12 PM
ls1fbody's Avatar
Haz l33t wheelz.
i do, i just left the USB cable in iraq. i'll see if i can find it and plug the card into my printer.
