help, 1st and 3rd gear jumping out of gear and grinding
Old Jan 6, 2010 | 06:47 PM
bernandovelasquez's Avatar
good day, was wondering if anyone can help me out and tell me whats wrong, I have a cobalt ss sc and have a twm sts installed, was working fine for months, but now when I put the car in first or third i hear a grind and the gear jus pops out and goes into neutral, sometimes if I get the gear in, it stays in gear and drive fine< I only get this once in every 10 tries... is this a big and expensive problem? does anyone know what this is about? thanks for your help if u can.
bump for help please.
Last edited by bernandovelasquez; Jan 6, 2010 at 06:47 PM. Reason: Automerged Doublepost
Old Jan 6, 2010 | 08:02 PM
qwikredline's Avatar
check roll pins at tranmission shift levers, check adjustment at the driver's shift lever, and hope the trans is not broken ...
Old Jan 7, 2010 | 02:07 PM
DaBuzzard's Avatar
^^^^X2 on the roll pins, they tend to break easily on these cars. If it is only partially broken, the tranny will not be going all the way into gear which will cause it to grind / pop out of gear when you let out the clutch pedal. If it snaps completely, you can't shift at all
Search the how to section for "roll pin", not a hard job to do yourself.
Old Jan 7, 2010 | 02:09 PM
BLAZIN07SS's Avatar
I'm too JDM for you
how is 5th gear acting? its sounding more like a shift linkage problem
Old Jan 7, 2010 | 02:29 PM
5th gear does the same thing!! thanks for all ur help guys I will def. be looking into checking out the roll pin, I'm reallying hoping my tranny is still good.
Old Jan 7, 2010 | 11:06 PM
LS6Rally's Avatar
check your STS and make sure the Linkage is still ok.
Old Apr 5, 2010 | 06:06 PM
chrismusaf@me.com's Avatar
It's the Roll Pin
I just picked up my Cobalt from the dealership for the exact same problem. The roll pin backs out and contacts the housing. They showed me this TSB:
https://www.cobaltss.net/forums/show....php?p=4143477
Good luck!
Old Apr 6, 2010 | 11:06 PM
jfowler55's Avatar
i had the same problem i had to get a new tranny and front diff and new clutch
Sl0wbaltSS
Nov 21, 2018 11:11 PM
Fearedbynone
Apr 14, 2016 03:25 AM
RaginChopsuey
Oct 27, 2015 01:27 PM
biniecki
Oct 25, 2015 02:23 PM
DocSvensk
Sep 27, 2015 02:24 PM
