Help ASAP!!!
Old Mar 17, 2012 | 02:53 PM
hawkssoccer11's Avatar
Help ASAP!!!
Working on my buddies 04 ion. He had to install a new clutch pedal and we bled the lines but now the car won't go into gear when idling. Also the clutch pushes in really easy. Don't know what else to do. Let me know if you guys can help out. Thanks
Old Mar 17, 2012 | 03:01 PM
ItalianJoe1's Avatar
Finish bleeding the clutch?
Old Mar 17, 2012 | 03:10 PM
asherby85's Avatar
bleed it again
Old Mar 17, 2012 | 03:20 PM
Were gonna let it sit for a little and go back to it. He said the clutch and brake run off the same reservoir. Would that effect anything?
Old Mar 17, 2012 | 03:31 PM
The problem is that you haven't bled it. They are a pain to bleed using the normal method. I'd suggest getting a vacuum bleeder, makes life much easier.
But you can do it normally, just bleed it until you get a pedal.
Old Mar 17, 2012 | 03:44 PM
Oh ok so if we have to bleed it for an hour lol
Old Mar 17, 2012 | 03:51 PM
asherby85's Avatar
sometimes it can take that long.
Old Mar 17, 2012 | 03:56 PM
Ok thanks man
Old Mar 17, 2012 | 06:14 PM
Then you need a vac bleeder. Takes time, but you don't have to waste any fluid or really do anything, just put it on and pump it up, let it sit, release, pump the pedal. Repeat a few times until it's perfect.
Old Mar 20, 2012 | 11:24 AM
SaberD's Avatar
make sure on the final bleed that you close the bleed screw while the pedal is going down and not after it is down.
Cobe
Sep 19, 2015 11:04 AM
06noscobaltss
May 25, 2006 01:55 PM
Saki XL
May 16, 2006 01:34 AM
9JordonFlex9
Mar 26, 2006 08:05 PM
Cobalt30
Mar 11, 2006 02:50 AM
