Help..Wont go into gear
Old Jun 13, 2010 | 06:48 PM
KillaTornado's Avatar
got a 06 ss sc juss put an exedy clutch in and it wont go into gear when on unless you rev it up a lil bit im thinking i need to vac bleed it but not sure ....also wont go in reverse unless i cut the car off and crank it with it in reverse someone please help
Old Jun 13, 2010 | 09:05 PM
Iam Broke's Avatar
Sounds like it's dragging a bit.
Hopefully you replaced the slave cyl when you were in there with an upgraded one. (LNF) Vacuum bleed it 3 or 4 times.
Pump the pedal 10 times, vac bleed it, slowly release the vacuum, pump it several times again, apply vac, ect. Repeat until satisfied.
Old Jun 22, 2010 | 02:51 PM
BNS06Mike's Avatar
look into your roll pin
or have it into a shop and see what they say
i am currently having the exact problem and it is my slave cylinder and my shift fork.
thats my advice to you
Old Jun 22, 2010 | 04:01 PM
yeah i tried bleeding it even said F... the roll pin and put a hex bolt through it with a nut tried bleeding the thing ....eventually gave up and took it to the shop i should be getting it back today hope u find out the problem ...yeah my kit came with new slave
Old Jun 26, 2010 | 02:00 PM
rkenny97's Avatar
could be linkage or clutch rod that was myproblems
Old Jun 26, 2010 | 03:33 PM
chevysssc's Avatar
linkage pin my guess
Old Jul 3, 2010 | 01:22 PM
ssscs10's Avatar
the whole problem is the throw out bearing. with dot 3 brake fluid. change ur throw out bearing and upgrade to dot 4 or 5. tthe dot 3 is boiling and killen u. ive gone through too many of these and have it figured out now.
Old Jul 3, 2010 | 01:28 PM
blk06cbltss's Avatar
just had this happen and it was my roll pin
Sl0wbaltSS
Nov 21, 2018 11:11 PM
RaginChopsuey
Oct 27, 2015 01:27 PM
biniecki
Oct 25, 2015 02:23 PM
DocSvensk
Sep 27, 2015 02:24 PM
brett.higgins3
Sep 24, 2015 09:51 AM
