How To Balance Shaft Delete
Old Feb 21, 2012 | 05:53 PM
mongorat427's Avatar
Heres a quick how to. Delete your balance shafts. First center punch the center of the balance shaft bearing housing. Next drill and tap it to 3/8 pipe thread. Next look in the hole you just made and locate the oil galley hole straight underneath the hole you just drilled. (And um not talking about your old lady.) Now drill and tap that out to 1/8 pipe. Clean the galleys out real good. Now get a 1/8 inch allen galley plug and put some loctite on it and thread it in the oil galley. Next thread your 3/8 plug into the big hole. Your done with that side. Repeat on the other side. Next take your old balance shafts and cut the front journal off so it looks like the picture. Your need these to run your water pump. Your can get everything you need at Lowes. This can only be done if the engine is completely apart. Clean the galleys very good when finished
Old Aug 4, 2012 | 04:06 PM
BlkWdoSS's Avatar
have you had any issues since you completed this? looking at doing it while my motor is out
Old Aug 4, 2012 | 04:35 PM
Used this block in my buddies LSJ 80
lbs oil pressure
Old Aug 4, 2012 | 06:45 PM
BlkWdoSS's Avatar
ok great, going to do it while ive got the motor out of my car. Dont want to **** the money away for neutrals or a kit thats irreversible
Old Feb 25, 2013 | 02:08 PM
jonnymerk's Avatar
bump have other guys still done this with success? I need to budget my build and this could save me money while the block is out.
Old Feb 25, 2013 | 02:11 PM
mkulrey13's Avatar
Point of this?
Old Feb 25, 2013 | 02:28 PM
Sox-Fan's Avatar
Got Brakes?
^^ This. Thanks for asking.
Old Feb 25, 2013 | 05:19 PM
its in the lsj build book, and recomended on certain cam setups. ( i believe zzp stage 2 and up )
the balance shafts are counter balanced, and turn as the motor runs and neutralizes viberations off the motor to make the ride more comfortable for the user. The act of spinning two counter balanced pieces takes away hp. how much? ive been told 7-12. How true is this? Not 100% sure.
However deleting these will free the motor the stress ( not much ) of having to turn them, and free up that said hp, but in return vibes will be more present in the cabin.
Benefit vs cost + install is more than 90% of the members on this site are willing to subject to.
Old Feb 25, 2013 | 05:21 PM
TStone's Avatar
less rotating mass, mo powa (within reason).... higher you rev, the more beneficial it is.
Old Feb 26, 2013 | 02:46 PM
jonnymerk's Avatar
I was merely asking if others had tried this with equal success. I showed it to my installer however since then, and it was exactly what he was looking for. My block had to come out regardless and any inexpensive improvements to performance I can make I'll take. My motor build was very unplanned and therefore out of my budget, but unavoidable.
Old Feb 26, 2013 | 02:52 PM
Staged07SS's Avatar
Administrator
Administrator
Yep.
Reving above 7500 rpm NB shafts should be installed.
About 10 hp is gained from this, but like 07MetallicSC said, 90% of the members on here would never attempt this.
Old Feb 26, 2013 | 02:53 PM
zrated89's Avatar
i run the neutrals, no vibes what so ever. Paid 50$ for them. GM ones too not zzps
Old Feb 26, 2013 | 02:55 PM
Staged07SS's Avatar
Administrator
Administrator
I was going to get me a set of the GMR NB's, but I have no plans of ever reving over my current rev limit of 7.5k anymore. It's plenty for me
Old Feb 26, 2013 | 02:59 PM
zrated89's Avatar
me 8200 on the blower. Now turbo hhhmmmmmm lol
Old Feb 27, 2013 | 07:14 AM
Staged07SS's Avatar
Administrator
Administrator
Awesome stuff!!!
I don't think my 42's would like 8200 rpm, haha.
Old Feb 27, 2013 | 07:27 AM
JapEatr's Avatar
South Central *********
Good write up.
Im in the camp that believes they do not need to be removed to rev high.
I have never heard of a failure, build book only mentions hp.
I upshift at 8k on my built motor. Guess ill let you know how it holds up
Old Feb 27, 2013 | 12:36 PM
zrated89's Avatar
i revved to 7600 on the stockers forever stock cams, valve springs, and balance shafts
Old Feb 27, 2013 | 12:39 PM
Staged07SS's Avatar
Administrator
Administrator
Ur wacky Kenny
Those stock springs were probably crying bloody murder at that rpm, haha.
Old Feb 27, 2013 | 01:12 PM
zrated89's Avatar
lol yea sometimes i would feel her break up from valve float but stayed in her
Old Feb 27, 2013 | 01:29 PM
Staged07SS's Avatar
Administrator
Administrator
Ur lucky you didn't drop a valve man
Well, you could fix it anyways. No worries.
Old Feb 27, 2013 | 01:34 PM
zrated89's Avatar
yep never did. The one time i didnt have float was when she ran a 11 but no slip print out
Old Feb 27, 2013 | 01:35 PM
Staged07SS's Avatar
Administrator
Administrator
Figures!
Old Apr 16, 2013 | 12:41 PM
BogusSVO's Avatar
Quick question... Why all the drill tap and plug? Why not just knock the rear BS bearings down about .150 of an inch and block the oil feed passage that way?
Old Apr 17, 2013 | 04:55 PM
Thats another way to do it but dont miss. I ended up using the Level Zero replacement sleeves on my other block with my Bal Shaft Delete .
Old Jul 30, 2013 | 09:11 AM
FasterIsBetter's Avatar
Yeah, I'd definitely rather go with the level zero replacement sleeves. Drilling and tapping the block puts you at a greater risk of the porous block/cracking issues that we all know the ecotecs pose due to improper castings.
