how critical is a flywheel?
Old May 27, 2008 | 08:44 AM
ifknrock09's Avatar
ok first of all i am getting a new clutch. but am not getting a light weight flywheel. (lack of funds) but how critical is it to get the stock one resurfaced or get a stock replacement? or can you just get a new clutch and slap it in. i have never had to replace a clutch before. thanks.
Old May 27, 2008 | 08:47 AM
2K5SS/SC?'s Avatar
Really it depends on how the flywheel looks. If it's not gooved or hot spotted badly, then you might be able to get away with scotchbright padding it real quick and then using some brake cleaner on it. If it is indeed bad, you should take it off and have it resurfaced, but GM calls for it to be replaced due to it being a stepped design, and they are hard to resurface.
Old May 28, 2008 | 08:41 AM
ifknrock09's Avatar
i see. so what are the advantages and disadvantages of a lighter flywheel. i know the basic principle of it but explain it to me like i'm 2
Old May 28, 2008 | 08:47 AM
Forced>Induction's Avatar
quicker revs, freer spinning motor, figure any weight that is removed from the flywheel is making it easier to spin the motor (rotating mass).
Old May 28, 2008 | 08:49 AM
Jackalope's Avatar
A lighter flywheel is great to have to be sure but not needed. However if you install a new clutch on an old flywheel thats NOT re-surfaced all your doing is setting yourself up for another new clutch sooner rather then later. Spend the few bucks to get it turned, it needs it.
Old May 28, 2008 | 09:58 AM
lsjwannabe's Avatar
^^ ding ding ding
Old May 28, 2008 | 10:58 AM
BlackSS/SC's Avatar
As 2K5SS/SC? said, you can't turn the flywheels in these cars. It messes with tolerances.
Old May 28, 2008 | 11:38 AM
2K5SS/SC?'s Avatar
GM recommends them to be replaced. If you can find a good machine shop however, it can be resurfaced, but the dowel pins have to be removed and both levels have to be cut exactly the same. The local dealership did it when I let them mess up my car. The flywheel came out fine, it was just the idiots that installed it and the bad clutch from ClutchMaster's that was the issue.
jas09ss
Sep 26, 2015 01:06 PM
n20saturn
Sep 21, 2015 01:50 AM
ashalle2
Sep 16, 2015 10:36 PM
brett.higgins3
Sep 14, 2015 01:48 PM
