hurst or b&m short throw shifter?
Old Mar 14, 2010 | 11:44 PM
wambo92's Avatar
not sure if I want to go with the hurst short throw or the B&M short throw. what does everyone think?
Old Mar 14, 2010 | 11:46 PM
HB_SS/TC's Avatar
neither
TWM
Old Mar 14, 2010 | 11:53 PM
sp123's Avatar
bump twm. I love mine
MT0911's Avatar
Twm = ftw
Old Mar 15, 2010 | 01:06 AM
ChevyRockstar's Avatar
Pics of TWM?
Old Mar 15, 2010 | 01:13 AM
K0ba1t 5s's Avatar
Originally Posted by ChevyRockstar
Pics of TWM?
go to the website and look at the directions or go to my pictures i have a pic of it installed
its truly the best sts out there, ive had mine for about a year and so far there has been no problems, perfect shifting
its a little bit more pricey but its worth it to me
Old Mar 15, 2010 | 01:14 AM
Gestapo007's Avatar
TWM is a great shifter. I find it a little more difficult to put it in gear over the B&M though. Its just a stiffer shifter. But seems great though.
Old Mar 15, 2010 | 01:31 AM
Boosted_Cobalt09's Avatar
twm definately
Old Mar 15, 2010 | 11:38 AM
TWM Performance's Avatar
Old Mar 15, 2010 | 06:46 PM
chitala383's Avatar
TWM is teh sexxxxx!!!!!!!!!
Old Mar 15, 2010 | 06:57 PM
wambo92's Avatar
i looked at the twm shifters. they are more expensive and that kinda sucks. the other issue i have is i do not like the polished shifter. can it be switched for a different color? on the site i looked at all the different color ones were weighted and i can't bring myself to spend 80+ dollars on a shift knob.
where is the best place to buy twm shifters?
Old Mar 16, 2010 | 02:57 PM
Our Cobalt SS short shifter is more expensive than the other short shifters available because the overall quality is better. We use TIG welding on the shifter shaft/main pivot ball where other short shifters are using a spring pin that tends to come lose. We also use a combination of delrin bushings and rubber o-rings for the reverse lockout mechanism where on others it's metal sliding directly on metal. The operation of the RL is much more smoother on ours.
Plus, it's also the most aggressive both in height and throw reduction. I don't believe any other vendors stock our Cobalt short shifter, you can buy it directly from our site on the following link:
TWM Cobalt SS short shifter
Old Mar 16, 2010 | 06:13 PM
wambo92's Avatar
are there any other color choices for the regular shift knob? i would like a gun metal or black
Old Mar 16, 2010 | 06:24 PM
07ss_PJ's Avatar
I have the hurst now. I like it. And it does what it's designed to do.
Question about the TWM though...
Can you put MOMO knobs on the shifter?
Old Mar 16, 2010 | 06:36 PM
TurboTechRacing's Avatar
FYI, B&M is not available any more (discontinued), Hurst and TWM are the options...
Old Mar 17, 2010 | 09:54 AM
wambo92's Avatar
I bought the twm last nite. Can't wait to get it so I can install it. Hope it's not too hard to install.
Old Mar 17, 2010 | 10:10 AM
Installation is a peice of cake with the manual. Thanks for the order!
Old Mar 17, 2010 | 10:13 AM
turbaltss's Avatar
Smart choice, pretty simple to install (instructions are included) just take your time to adjust the cables properly, both need to be adjusted the instructions don't really say to adjust both but it is needed.
Old Mar 17, 2010 | 10:44 AM
In the Cobalt SS/TC, for some reason both cables sometime needs to be adjusted. In every SS/SC I worked on though, I never needed to adjust the second cable.
If you need to adjust the cable that controls the side-to-side movement of the shifter (basically to get a better engagement of the 5th gear and reverse) you will need to adjust it the same way as it's pictured in the manual to adjust the other cable. Very straight forward.
Thanks,
Frank
TWM Performance
Old Mar 17, 2010 | 11:03 AM
07ss_PJ's Avatar
TWM...will MOMO knobs fit on the shifter?
Old Mar 17, 2010 | 11:20 AM
As far as I know their shift knobs use set screws to secure to the shifter so it would interfere with the RL mechanism of the Cobalt short shifter.
Old Mar 17, 2010 | 02:34 PM
Gestapo007's Avatar
I installed a TWM on my buddies SS/TC, and I could NOT get one of the rubber base bushings out to change from the stock shifter. it just would not come loose. i couldnt even get the black plastic assembly out because it was just stuck. flat heads prying on it and everything wouldnt break it loose. That was crazy. We wound up just not installing the metal base bushings
Old Mar 17, 2010 | 02:35 PM
SSMOKEM's Avatar
Did anyone say TWM
Old Mar 17, 2010 | 09:19 PM
wambo92's Avatar
do you sell any other shifter knobs that will work that are not weighted?
Old Mar 18, 2010 | 09:22 AM
The aluminum shift knob we sell with the short shifter is a similar weight to the stock Cobalt shift knob:
Aluminum M1 Abrams RL
