hurst shifter
Old Jan 8, 2008 | 07:55 PM
Dayta's Avatar
hurst shifter
just ordered a hurst shifter for my car
anyone know the difficulty level on installing one?
thanks
Old Jan 8, 2008 | 09:13 PM
DoMiStIc_RuSh_06's Avatar
Its a big pain in the ass. It took me 4 or 5 hours to try and figure it all out and get a picture of how it was goiong down....
Old Jan 8, 2008 | 09:14 PM
OneSlowGto's Avatar
10 minute install. Consult BECK for install directions.
Old Jan 8, 2008 | 09:15 PM
SlowBalt_06's Avatar
ha ha its 15 mins
Old Jan 8, 2008 | 09:16 PM
kenhebe's Avatar
Unless you are very mechanically inclined, I would not recommend doing it. It took one of my techs about 1.5 hours to install it start to finish and he is very talented. You should have gone with B&M though. Hurst re-uses the factory plastic bushings where as B&M has solid billet aluminum.
OneSlowGto's Avatar
He has gotten faster.
Old Jan 8, 2008 | 09:17 PM
heyitsmikey1987's Avatar
tookme 30 mins a.d.d. moment slowed me down
Old Jan 8, 2008 | 10:05 PM
Kibosh3's Avatar
i installed mine tonite...its not difficult at all, u just have to kknow wat/how u want to accomplish... a few pieces of advice:
- dont strip the cheap set-screw like i did
- use the loc-tite
- ADJUST BOTH CABLES...many people complain that reverse lockout doesnt work...it didnt work wen i first installed it on mine eitehr...until i ADJUSTED BOTH CABLES...now the shifts are as smooth as butter AND i got my lockout
Old Jan 8, 2008 | 10:20 PM
spaz's Avatar
You only have to adjust the white clipped cable to get reverse lock out working and by doing this you misalign 3rd. That's why I took mine out and chopped down the stock one. Much nicer.
I'd recommend getting a good set screw at home depot.or where ever. The one that comes with it sucks.
Old Jan 8, 2008 | 10:49 PM
Kibosh3's Avatar
^^ yup...home depot ftw
Old Jan 9, 2008 | 02:06 AM
syP's Avatar
syP
word of advice....
just follow the directions if came with.
Old Jan 9, 2008 | 02:19 AM
cobaltssjoe's Avatar
takes about 30 minutes, just be careful installing it
dont break anything off like i did
Old Jan 9, 2008 | 05:31 PM
Dayta's Avatar
ok thanks everyone for the advice
when i get it and instll it ill post up how i did
Old Jan 9, 2008 | 05:36 PM
an0malous's Avatar
follow the directions carefully and its 30 minutes or less
and spend a little time adjusting the cables to get your gears alligned properly.
Old Jan 9, 2008 | 05:38 PM
invisible's Avatar
Wow guys, come on, i am decent at best with mechanical things and only took me like 45 mins. As for the set screw, dont even try to use it. If you do, the shifter will move around alot. Either re-thread it and use a bigger set screw, or do what i did and drill out a small indention in the shifter so the set screw will go into the shifter about 2 millimeters.......now its solid as it can be.
Old Jan 9, 2008 | 05:51 PM
CREW54's Avatar
I just put mine in last Saturday. It is not difficult at all....just a little confusing at first when have the console apart. IMO, the Hurst instruction were BS. Over-all, I like the shifter. It shifts perfect...Reverse Lock-Out not used on mine.
Old Jan 9, 2008 | 05:58 PM
invisible's Avatar
You can make it work. Just adjust the cable that is connected with the white and gray connector. If you take your time you will love it. The people that dont like it are the ones that just throw it together real fast and dont take there time to adjust it.
Old Jan 9, 2008 | 06:07 PM
3fo893013L's Avatar
took me an hour. the directions suck. make sure to label the positions of the cables with a marker (that you can see). You only have to disconnect the right hand side cable (passenger side). DO NOT under any circumstances disconnect the drivers side cable. What a pain in the ass. Make sure you put it in a gear you know.
Old Jan 12, 2008 | 11:27 AM
Dayta's Avatar
how long did it take to get the stock shift off??
cuz iv been workin on it for like 45 min, and it still doesnt seem to budge
Old Jan 12, 2008 | 11:43 AM
tombomb's Avatar
15 mins with frequent beer breaks, about a 3-4/10 dificulty level
5 mins, just requires a little force
Old Jan 12, 2008 | 11:44 AM
craigk_c19's Avatar
yeah it only took me abvout 45mins for the whole install but i think im going to go back in and redo the set screw b/c i hate how much it moves around on me and try to mess with both cables to try and get the lockout to work!!
Old Jan 12, 2008 | 11:46 AM
tombomb's Avatar
true^^^^ the allen wrench they suplied actually striped my set screw so im "screwed" i got it pretty tight but it still moves a little
Old Jan 12, 2008 | 11:50 AM
jonnymerk's Avatar
Yikes I did the TWM swap on my old 2.2 and it was a breeze. Is it worth it to swap in a short throw on the SS? I guess I mean is the difference that night and day like it was on the 2.2.
craigk_c19's Avatar
mine only will twist a little to the left but it won't even move a little when you twist it right so on up shifts it feels fine but i feel like its going to fall apart on me on the down shifts!
Old Jan 12, 2008 | 02:39 PM
CREW54's Avatar
Hardest part of the whole install for me was removing the stock shifter knob from the splined shaft...MF'er didn't want to come off!!!
