hurst shifter
Old Jan 12, 2008 | 02:50 PM
Super_SS's Avatar
also had a question,might be little off topic,but im sorry,
is there anyway to make the shifter stiffer,like the srt4 shifter's maddog has for the neons,its short,but stiffer..i replaced all my bushings and still isnt really stiff,feels like stock
Old Jan 12, 2008 | 09:07 PM
Dayta's Avatar
just installed it
5th gear and reverse is kinda wierd, but its workin
ill take is out for a spin in a bit and check it out, i love the look of the shifter
Old Jan 12, 2008 | 09:15 PM
CobaltSS 16's Avatar
Originally Posted by Dayta
just installed it
From what I've heard, you might need to adjust it further.
Old Jan 12, 2008 | 09:21 PM
Dayta's Avatar
yep that what it was
now it shifts like a charm
i drilled a hole into the shifter so the allen set screw would actually set, awesome idea
thanks everyone
Old Jan 12, 2008 | 09:34 PM
lsjwannabe's Avatar
not to bad to do
Old Jan 13, 2008 | 10:28 AM
tombomb's Avatar
ya there isnt much you can do about 5th gear, it is easy to get use to
Old Jan 13, 2008 | 10:37 AM
kenhebe's Avatar
Should've gone with B&M. Much better shifter
Old Jan 13, 2008 | 11:39 AM
an0malous's Avatar
yes there is.
adjust the cables properly.
My hurst, and others ive installed for people....have exactly the same shift gates as stock.
except crisper and shorter.
Old Jan 13, 2008 | 12:56 PM
kenhebe's Avatar
Originally Posted by an0malous
yes there is.
x2
Old Jan 13, 2008 | 06:06 PM
CREW54's Avatar
yes there is.
X3
Old Jan 20, 2008 | 12:48 AM
  #36
craigk_c19's Avatar
does reverse lock out work for yall??^^^
thanks everyone
how did you do that b/c i want to lose that little bit of twist that mine does!!
Last edited by craigk_c19; Jan 20, 2008 at 12:48 AM. Reason: Automerged Doublepost
Old Jan 20, 2008 | 01:02 AM
  #37
Dayta's Avatar
just take a drill and a bit a little bigger than the set screw.
but first took a sharpy marker and mark the end of the set screw and then tightend it all the way into the shifter. and when you take it back out, you have a mark where you need to drill
and drill about an 1/8 into the shifter
Old Feb 2, 2008 | 11:50 AM
  #38
craigk_c19's Avatar
^^X2 worked great and like yall said i played around with both cables and now it feels just like stock! and my reverse lock out even works now took about 30 mins to get it right tho but worth it!!
Old Feb 3, 2008 | 03:15 AM
  #39
3fo893013L's Avatar
well you shouldn't have to do anything with drilling. Installed in an hour and have the same feel as stock but better. Perhaps on certain model years they did revisions. Mine is an 05 and I didn't have to do half the **** other people did.
Old Feb 3, 2008 | 01:33 PM
  #40
craigk_c19's Avatar
i really didn't have to drill its just that if you twist it it would twist a little bit and i didn't like that so i just drilled a little hole and now its really firm and mine is an 05 too and only took me about 45 mins to install but after i had it installed my reverse lock out didn't work and the gears felt like
1_3_5__ Now its just 1_3_5
Old Feb 4, 2008 | 11:27 PM
  #41
fastss25's Avatar
anyone know the size of the set screw?? I love my hurst shifter!! Does move around a lot. So, I am going to fix that like you guys said go to a better set screw. Only thing that sucks about it is on hot days it gets hot and on cold days it is very cold!! lol..
Old Feb 4, 2008 | 11:33 PM
  #42
Coblt ss super's Avatar
im gunna get a hurst in the summer, how do you adjust the cables?
007Buff
Jun 11, 2017 03:04 PM
biniecki
Oct 25, 2015 02:23 PM
Cptnslo
Sep 24, 2015 09:32 AM
007Buff
Sep 22, 2015 09:48 AM
The Rookie24
Sep 20, 2015 04:33 PM
