Hurst short throw..
Hurst short throw..
Installed the hurst short throw this morning on my 10' ss..it was a pain in the ass..but after the install, all the gears go in fine except 5th gear.. it goes in but I kinda have to move it around to find it.. the shifter will go side to side in neutral, but it will go far if I move it to the right towards 5th..and when I move it all the way to the right and push up to go in fifth, it wont go, id have to bring it back to the left a little bit and then push up for fifth, so if you understand what im trying to say, did I do something wrong here?
Yeah it actually moves 5th inward so that all gears all equal distance instead of 5th being all the way out to the right. If you stick with it you'll eventually learn the new position and it'll become second nature.
Reverse lockout isnt what keeps it from going all the way to the right....... reverse lockout is what keeps it from going into reverse, hence the name. Its the thing you pull up to get into reverse. If you have a newer version of the hurst then your reverse lockout should work.
Theres really no way to get rid of the space out towards fifth. Your cables should stay in the same orientation as they were on your stocker. If you want a better shifter then you should probably try TWM. Hurst is the nicest looking in my opinion though.
