Hurst short throw..
Old Dec 18, 2010 | 07:04 PM
seeyaass's Avatar
Hurst short throw..
Installed the hurst short throw this morning on my 10' ss..it was a pain in the ass..but after the install, all the gears go in fine except 5th gear.. it goes in but I kinda have to move it around to find it.. the shifter will go side to side in neutral, but it will go far if I move it to the right towards 5th..and when I move it all the way to the right and push up to go in fifth, it wont go, id have to bring it back to the left a little bit and then push up for fifth, so if you understand what im trying to say, did I do something wrong here?
Old Dec 18, 2010 | 07:05 PM
tylerjclance's Avatar
USA Y U NO HAVE AUTOBAHN?
the sts makes a smaller shift pattern (i think?), took me a few hours to get used to it, but once you do you'll like it more.
Old Dec 18, 2010 | 07:06 PM
BPacak's Avatar
Vtec Rep
suckks haha. i think the stock is short enough
Old Dec 18, 2010 | 07:07 PM
Pyros777's Avatar
Yeah it actually moves 5th inward so that all gears all equal distance instead of 5th being all the way out to the right. If you stick with it you'll eventually learn the new position and it'll become second nature.
Old Dec 18, 2010 | 07:25 PM
seeyaass's Avatar
So its supposed to have that large gap of nothing to the right?
Old Dec 18, 2010 | 08:08 PM
Pyros777's Avatar
Yes, and reverse is still all the way to the right.
Old Dec 18, 2010 | 08:29 PM
seeyaass's Avatar
Lol I know reverse is.. but I just found it odd.
Old Dec 18, 2010 | 08:38 PM
Shez's Avatar
I hated that about my Hurst. It just gets rid of the reverse lockout. At least mine did. The lockout is what would stop it from having all that "extra space" to the right of 5th.
Old Dec 18, 2010 | 08:41 PM
Black08SSTC's Avatar
u still have that shifter? ill buy it back from you
Old Dec 18, 2010 | 10:25 PM
seeyaass's Avatar
Really? Is there a way to make the lockout work??
Old Dec 18, 2010 | 11:04 PM
seeyaass's Avatar
I heard there is a way to get the lockout work.. is this true? If so how to do it?
Old Dec 19, 2010 | 01:37 AM
Pyros777's Avatar
Reverse lockout isnt what keeps it from going all the way to the right....... reverse lockout is what keeps it from going into reverse, hence the name. Its the thing you pull up to get into reverse. If you have a newer version of the hurst then your reverse lockout should work.
Old Dec 19, 2010 | 01:39 AM
BlackJackSS's Avatar
make sure the shifter does not move at all left to right when twisting it. if that lock screw aint tight enought it will make 5th hard to get to. and sloppy shifts.
Old Dec 19, 2010 | 01:42 AM
Pyros777's Avatar
I hear the new version of the hurst addressed that issue with a bigger set screw.
Old Dec 19, 2010 | 02:53 AM
Shez's Avatar
Yeah, man. Awesome let me know when.
Old Dec 19, 2010 | 03:29 AM
Whining-devil's Avatar
same thing with my hurst, it kept the reverse lockout but 5th wasnt all the way to the right, got rid of it and bough a B&M.
Old Dec 19, 2010 | 06:02 PM
seeyaass's Avatar
So theres no way to get rid of that extra space towards fifth?
Old Dec 19, 2010 | 06:04 PM
should have gone with twm
Old Dec 19, 2010 | 06:29 PM
seeyaass's Avatar
Shoulda coulda woulda, im stuck with hurst, any way to fix this extra space by fifth?
Old Dec 19, 2010 | 06:36 PM
crazy-eh666's Avatar
i dont think there is a way to get rid of the extra space at 5th. you will prob just have to get used to it. also, getused to tightening the setscrew every 1000 km or so.
Old Dec 19, 2010 | 06:50 PM
seeyaass's Avatar
Dam really? How's twm?
Old Dec 19, 2010 | 07:30 PM
i modded my hurst shifter with a bigger screw too lol. and red locktite
Old Dec 19, 2010 | 07:43 PM
WSFrazier's Avatar
Try adjusting the cables.
I had to play with mine a few times to get it perfect. Drag strip is a real good place to get it all tuned in, except this time of year.
Old Dec 19, 2010 | 07:49 PM
Pyros777's Avatar
Theres really no way to get rid of the space out towards fifth. Your cables should stay in the same orientation as they were on your stocker. If you want a better shifter then you should probably try TWM. Hurst is the nicest looking in my opinion though.
Old Dec 19, 2010 | 08:07 PM
WSFrazier's Avatar
The Hurst chips very easily and will look like **** in 6-12 months just from your hand touching it.
I regret buying it.
