hurst STS prob fixed?
Old Feb 11, 2010 | 05:11 PM
kretty's Avatar
did they fix the reverse lockout problem?
Old Feb 12, 2010 | 02:05 PM
SlobaltSS/C's Avatar
its not a problem, it was designed to be more of a universal fitment, and does require some modification of the stock shift unit to make it fit properly on our cars.
Old Feb 12, 2010 | 04:33 PM
kretty's Avatar
Modifications as far as?
Old Feb 12, 2010 | 04:37 PM
alleycat58's Avatar
Modifications as in you have to just adjust the cables so that the shifter works with the lockout. They've been complaining about "problems" since they came out for the SS/SC. The solution's still the same - ADJUST THE CABLES.
Old Feb 12, 2010 | 05:38 PM
kretty's Avatar
I heard grinding was needed on a small part of the lockout.
Old Feb 12, 2010 | 09:24 PM
Sweetsandman's Avatar
I installed mine in 20 minutes...And didn't bother to get the reverse lock-out to work...I could've adjusted the cables and all that jazz but...I don't like reverse lockout anyways...far better without it IMO...useless invention.
Old Feb 12, 2010 | 09:30 PM
thedude411's Avatar
it takes like all of 2 minutes to figure out where u need to position the cables. its mint in my mind.
Old Feb 13, 2010 | 01:48 AM
leviticus88's Avatar
I had to drill and retap the set screw on mine and locktite about a year after I first installed it. Only issue I have had.
I disabled the reverse lock out and with a chisel removed the plastic section of the shift unit that catches the reverse lock out potion of the STS.
This way the cables can be adjusted to your taste and it has worked flawlessly for 3+ years.
Old Feb 13, 2010 | 01:55 AM
ls1fbody's Avatar
Haz l33t wheelz.
mark the cables before you uninstall the stock shifter. I never adjusted mine, and the reverse lockout works and everything just fine.
dieGone
Oct 1, 2015 06:27 PM
footballplaya3k
Sep 30, 2015 09:39 PM
Tupp
Sep 30, 2015 08:18 PM
yellow dragon
Sep 28, 2015 09:49 PM
SlowSaturn
Sep 28, 2015 11:03 AM
