Hurst STS on T/C
Hurst STS on T/C
Does anybody have pics of the Hurst Short Throw Shifter for there SS T/C? Also how hard is the installation? How do you guys like it , is it shorter than the stock "short throw"
if your going to do it, do it right with a TWM STS, also get the aluminum bushings. Hardest part is getting the stock knob off, its pressed on. It can be done following the directions though.
The installation of a short shifter is very straight forward, as hiltu mentioned the only part that be more difficult is to actually remove the stock shift knob. Otherwise, make sure both the shifter cables are properly aligned before putting everything back in place.
Frank
TWM Performance
