Clutch troubles
Old Sep 3, 2009 | 09:33 PM
trey ss's Avatar
Clutch troubles
a lil while ago i felt something funny with my ss s/c and kinda blew it off.. then yesterday i hit it kinda hard on 4th and the rpms went straight to redline...
then i came home freaked out and told my dad, and he drove and instantly knew it was the clutch and said it is bad and needs replaced soon..
i read the thing about the clutch sliping fix.. but idk if that would apply to me and if not what kind of clutch should i be looking at?
Old Sep 3, 2009 | 10:14 PM
StreetLC's Avatar
How many miles are on the clutch? Depending on your intentions with the car, id say go with the GM upgraded clutch. I just put it on my car and i am running a good list of mods and it holds great. If your heavly modded and go to the track a lot id say exedy all the way.
Old Sep 3, 2009 | 10:28 PM
trey ss's Avatar
its got 60k on it and im the 2nd owner so idk how it was treated b4 me, i dont go to the track that much, but i run it pretty hard sometimes
Old Sep 4, 2009 | 01:17 AM
calicobaltSS's Avatar
yeah...get the upgrade clutch kit...I have it installed also....$300 from C.E.D. well worth the money....
Old Sep 4, 2009 | 08:03 AM
trey ss's Avatar
what is C.E.D
Old Sep 4, 2009 | 08:06 AM
sport08's Avatar
Originally Posted by trey ss
what is C.E.D
crate engine depot
Old Sep 4, 2009 | 02:15 PM
StreetLC's Avatar
what is C.E.D
this is what you want
http://www.crateenginedepot.com/Ecot...P2301C229.aspx
Old Sep 5, 2009 | 11:57 PM
trey ss's Avatar
will this kit have everything i need to replace a slipping clutch
Old Sep 16, 2009 | 04:54 PM
sanchez's Avatar
quick question will this eco tech clutch upgrade work on a 2.4 na ss or is it just for the 2.o ss/sc
Old Sep 16, 2009 | 05:43 PM
Sharkey's Avatar
no its just for the 2.0l ss/sc. the clutches are different between the 2.2/2.4 and the 2.0l
Old Sep 16, 2009 | 11:22 PM
rcorona8's Avatar
Does it grab good when U go from 1st to 2nd on WOT?
Old Sep 17, 2009 | 01:48 AM
06SS ALL DAY's Avatar
try shifting at 3k for a couple of days... than do a few wot pulls. it should be fine
Old Sep 17, 2009 | 12:33 PM
trey ss's Avatar
i trired the how to on fixing the clutch slip. i have been shifting just over 3k.. i thinks it just bad. it still slips every time i hit the gas after a gear change.
Old Sep 17, 2009 | 12:56 PM
Ryan@zzp's Avatar
If you are going to replace your clutch I would upgrader further than the GM clutch. If you decide to change your power goals you won't have to upgrade again. Our stage 4 will hold all the m62 can throw at it. Our stage 4 plus is working great on the LNF and my twincharge setup, both making over 400ftlbs and lauching on slicks. They both have smooth engaugement and we offer a few different disc options to suit you needs.
Old Sep 24, 2009 | 09:16 PM
trey ss's Avatar
just finisshed up the install 2day.. feels good.. just gota break it in now
Old Oct 2, 2009 | 02:28 AM
SportredSS's Avatar
FYI: That's 400lbs\ft not ft\lbs... you cant put feet into weight-lbs..........^^^^
Too bad you cant NLS with that upgraded racing clutch.....
My clutchmasters stg3 is so bad it's doing harm to my tranny now without shifting past 4k rpm.....
Old Oct 2, 2009 | 12:10 PM
Ryan@zzp's Avatar
Thanks for the englissssssh lesson is will be sure tooo corect mysefl.
FYI: I can still NLF shift with our racing clutch, in both the LNF and my twincharge setup. Maybe you should run our parts and you could toooooo.
NLS isn't good for any tranny but people still do it. Harming your tranny is going to happen when you mod or beat on your car.
Old Oct 8, 2009 | 02:50 PM
06PEEQCHU's Avatar
clutch
I flush my entire brake/clutch master through everything add syntehtic higher temp brake fluid....what I found per a tsb. inspected the system and both fed through same resovoir. heating brakes raise's temp in whole system to slave cylinder. I did it at 60k and drove to 101500. But right now I'm looking into clutch and lsd upgrade.
check my profile for cars and mods
Zharrington_2010LNF
Feb 8, 2016 01:43 PM
RaginChopsuey
Oct 27, 2015 01:27 PM
SSLOW06
Oct 1, 2015 07:21 PM
Tupp
Sep 30, 2015 08:18 PM
