i lost 2nd,4th, and R...
Old Jun 28, 2008 | 12:33 PM
xx07cobaltss24xx's Avatar
ok my phone wont let me search today its being a pia... but has anyone ever had clutch fork problems?? or even the shift linkage? cause i JUST got the car back after the shifter broke completely now when i finaly decide to run up through the gears it breaks... 1st roll into it spins a little throw it into 2nd bark the tires, 3rd runnin better than ever i brought it up to boought 90-100 i let off i go to put it into 4th an (thinking bout slowing down when i go to put it) nothing...at all felt like i was in neutral so i try for fifth an it feels fine...i slow down an put into thrid an while iam slowing down i try again for forth an it goes... but when iam accelerating i cant get into 2nd or forth an now even from a dead stop i cant get it into reverse unless i put it into first and start to move the i can engage R....iam really gettin tired of bringin this car to the dealer... this will be the third time in less than 2 weeks...an 6th or 7th in the three an half months ive had the car
Old Jun 28, 2008 | 12:36 PM
mrniceguy8211's Avatar
Dude, you have some bad luck. Either beat on you car more, or maybe less. Either or, because the beating you are giving now isn't working. Check you linkage, my buddy had this problem on his HHR. It was his shift cables that went bad.
Old Jun 28, 2008 | 12:43 PM
well i really have takin it easy cause of gas...the only time iusally get on it is from rolls..an usally iam easy on it
does anyone have any info on where the linkage connects to tranny? cause iam thinkin Bout to do it my self lol
Last edited by xx07cobaltss24xx; Jun 28, 2008 at 12:43 PM. Reason: Automerged Doublepost
Old Jun 28, 2008 | 12:44 PM
I beat the living crap out of mine, It seems to work for me. My car has been good to me other than the Cat, steering colum, swaybar links, fuel injector O-rings, Belt tenchoner, lower conrol arms, and door hand that I have replaced since last year. Warrenty work FTW!
Check the end of you shifter cables, where they attach to the tranny. See if the plastic sleave or the rollpins broke.
Old Jun 28, 2008 | 12:45 PM
johnkb8's Avatar
had same problem on my old ss/sc, dealer fixed it right up, easy linkage fix
Old Jun 28, 2008 | 12:46 PM
Check out this tread.
https://www.cobaltss.net/forums/show...shifter+cables
Old Jun 28, 2008 | 01:36 PM
wow i fixed it i poped the cupholder an ran through the gears an one of the clips for the linkage poped up an out of place. so i pushed both back in an i checked the other one an it felt a lil loose so i pushed it in an it think wat happened was when they changed the shifter they didnt push it back it properly lol
Fearedbynone
Apr 14, 2016 03:25 AM
RaginChopsuey
Oct 27, 2015 01:27 PM
riceburner
Oct 2, 2015 05:47 PM
MrInsanityWolf
Sep 29, 2015 04:54 PM
jrocstar
Sep 26, 2015 11:42 PM
